I have settled on the following components:
Silverstone Sugo SG05B Mini-ITX Case - Black (300W PSU)
Zotac GeForce 9300-ITX WiFi Mini-ITX Motherboard
Intel Pentium Dual-Core E5200 2.50GHz - Retail
Kingston HyperX 4GB (2x2GB) DDR2 6400C4 800MHz
Western Digital Scorpio Black 320GB 7200RPM SATA-II
Samsung SN-S083A/BEBE DVD±RW SATA Notebook Drive
Akasa Slimline Optical SATA Cable
45cm Akasa AK-CB055 Right angle SATA II connector
I can't get the e5200 at OCUK any more it seems, but other places have it in stock. Cheapest I can build this is for £362.
I also intend to fit a Sapphire ATi 4770 either during the build, or at a later date, for an additional £80.
I have Win7 on pre-order, and would probably try and give RC a whirl beforehand. Intending to run Dawn War II as my only gaming requirement.
Would really appreciate any comments or glaring mistakes I could make before I press the buy button. My main concern is there seems to be a new PCB revision for the Zotac motherboard - how likely is it to get one of these?
