- 10 Nov 2006
I have picked up a new laptop today. Its a Samsung 550p5c with Windows 8. It looked a nice machine at the right price. Its got a Core I5 3210m @2.5ghz cpu. I decided I did not need a dedicated gpu, as gaming will be pretty non existent. I have had to give up my main rig, as we need the space for a new arrival, and this was its replacement. The most intensive task will be to encode a few DVD`s to my network storage.
The problem I am having is the processor speed seems to be locked. CPU-z identifies the processor and its max speed correctly, but reports a current working multiplier of 12, giving a speed of 1200mhz. It does not seem to matter what I do, I cannot get this to increase. I tried a Handbrake encode and got equal performance to a 4 year old Vostro laptop. Core temp reports 45-50 degrees on the cores. I have tried adjusting power settings etc, but I cannot seem to get anything to move. I downloaded passmark to double check and it scored roughly half what it should be capable off. The WEI gives a CPU score of 4.9, which is the lowest figure out of all the tested components. That can`t be right, surely.
Am I missing something stupidly simple? Its almost like there is a power management mode stuck. But I have changed them all multiple times this evening without success. It also makes no difference whether the power adapter is plugged in or not. I have had a quick look in the bios, and can`t see anything obvious.
Any suggestions would be greatly appreciated, as at this moment in time, I am very disappointed.
Re-installed the settings program and after a bit of faffing, the system works as it should.
