New Layout for our Loop
18 Sep 2020
The guys from ScuffedTubing™ are back, this time I just want to check this layout we created real quick, to make sure that we are on the right track:
lSHuwQq
lSHuwQq
https://imgur.com/a/lSHuwQq
This would be the layout, hardware stays the same for now, Distro Plate is the O11D-G1 one, we will use 90° Angles this time for everything instead of trying to bend them with the insert, as we hope for optimal water flow.
Thanks a lot guys for the help on the previous thread!
Yep, last image looks right.
Remember that if it's easier for you, you can route the inlet & outlet of the GPU in through one side. You don't need to have one coming in the bottom and the other going out the top
That looks right this time :)
If you use the BB link on imgur it will show
Your images instead of a link :)
Fingers crossed everything works well this time :)
