- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi
Check out the new Lian Li Cases at OcUK.
Lian Li PC-Q05A Intel DH-61AG HTPC Case - Silver @ £53.99 inc VAT
The PC-Q05 is designed for the Intel DH61AG ultra thin Mini-ITX motherboard and the Intel HTS 1155LP heat sink. The chassis features intake vent input cooling air to cool the system down. This tiny case can house up to two 2.5" HDDs for extreme data storage.
- Case Type: Mini Tower Chassis
- Dimensions: (W) 284mm x (H) 47mm x (D) 307mm
- Front bezel Material: Aluminum
- Side Panel: Aluminum
- Body Material: Aluminum
- 5.25" drive bay (External): None
- 3.5" drive bay (External): None
- HDD bay: 2.5-Inch HDD x2
- Motherboard Support: Thin Mini-ITX (intel® DH-61AG)
- Maximum Compatibility: Cooler: support the Intel HTS® 1155LP
- Package Dimensions: (W)346 mm x 98(H) mm x 343(D) mm
- Gross Weight: 1.5 KG
- Power Supply: AC 150W adapter (not include)
Only £53.99 inc VAT.
ORDER NOW
Lian Li PC-Q05B Intel DH-61AG HTPC Case - Black @ £53.99 inc VAT
ORDER NOW
Lian Li PC-Q12A Mini-ITX HTPC Case (with 300w SFX PSU) - Silver @ £119.99 inc VAT
Small is beautiful; however in the computing world small normally indicates you have to cut out perfomance for small size. The trend has been broken with the new PC-Q12 MiniITX Case ideal for any HTPC sat in front of the TV.
- Dimensions: (W) 88mm x (H) 365mm x (D) 208mm
- Net Weight: 2.4KG
- HDD bay: 2.5-Inch HDD x4
- Expansion Slot: None
- Motherboard Support: Mini-ITX
- System Fan (Front): None
- System Fan (Top): 80 mm Fan x 1
- System Fan (Rear): None
- I/O Ports: USB 3.0 x 2
- CPU cooler height max.: 55mm
- Power Supply: SFX PSU / OPTPUT : 300W / Efficiency : 80% (80-PLUS) Included
Only £119.99 inc VAT.
ORDER NOW
Lian Li PC-Q12B Mini-ITX HTPC Case (with 300w SFX PSU) - Black @ £119.99 inc VAT
- Net Weight: 2.4KG
ORDER NOW
Lian Li PC-Q15A Mini-ITX Cube Case with 300w SFX PSU - Silver @ £143.99 inc VAT
The PC-Q15A has bundles of space, yet being a Mini-ITX case, with space for 250mm GPU's and a 100mm high CPU Cooler. With a built in 300w SFX full PSU this case can house a monster spec'd system, but is beautifully small and compact at the same time.
- Dimensions: (W) 210mm x (H) 210mm x (D) 330mm
- Net Weight: 3.3KG
- 5.25" drive bay (External): 1
- HDD bay: 3.5-Inch HDD x1( Hotswap ) / 2.5-Inch HDD x3
- Expansion Slots: 1
- System Fan (Front): 120mm Fan x 1
- System Fan (Top): None
- Maximum Compatibility: VGA Card length: 250mm / CPU cooler height: 100mm
- Package Dimensions: (W) 260mm x (H) 270mm x (D) 366mm
Only £143.99 inc VAT.
ORDER NOW
Lian Li PC-Q15B Mini-ITX Cube Case with 300w SFX PSU - Black @ £143.99 inc VAT
The PC-Q15B has bundles of space, yet being a Mini-ITX case, with space for 250mm GPU's and a 100mm high CPU Cooler. With a built in 300w SFX full PSU this case can house a monster spec'd system, but is beautifully small and compact at the same time.
- Net Weight: 3.3KG
ORDER NOW
Lian Li PC-Q18B Mini-ITX Cube Case - Black @ £124.99 inc VAT
With a large 140mm front and top fan the PC-Q18 takes Mini-ITX cooling to new levels, allowing you to have the potential to run an overclocked system without the needs for large cooling area's within the chassis.
- Dimensions: (W) 199mm x (H) 290mm x (D) 365mm
- Net Weight: 3.35KG
- HDD bays: 3.5-Inch HDD x4( Hotswap ) + 3.5-Inch HDD x2 or 2.5-Inch HDD x3
- Expansion Slots: 2
- Motherboard Support: Mini-ITX / Mini-DTX
- System Fan (Front): 140mm Fan x 1
- System Fan (Top): 140mm Fan x 1
- I/O Ports: USB 3.0 x 2 / HD Audio
- Maximum Compatibility: VGA Card length: 340mm / PSU length: 160mm / CPU cooler height: 60mm
Only £124.99 inc VAT.
ORDER NOW
Lian Li PC-Q18A Mini-ITX Cube Case - Silver @ £99.98 inc VAT
Only £99.98 inc VAT.
ORDER NOW
Lian Li PC-V700B Midi Tower Case - Black @ £186.95 inc VAT
The PC-V700 is smooth as silk, but strong as a tiger. The Lian Li designers used a 140mm intake fan at the front, running with a low RPM, but still move enough air into the chassis, providing the best balance of silence vs cooling. This chassis has a front mounted PSU providing the perfect balance for space and hardware performance needs.
- Case Type: Mid tower chassis
- Dimensions: (W) 210mm x (H) 400mm x (D) 496mm
- HDD bay: 3.5-Inch HDD x4( Hotswap ) / 3.5-Inch HDD x2 / 2.5-Inch HDD x2
- Expansion Slots: 8
- Motherboard Support: ATX / Micro ATX
- System Fan (Top): 120mm Fan x 2
- System Fan (Rear): 120mm Fan x 1
- I/O Ports: USB3.0 x 2 / USB2.0 x1 / e-SATA x 1 / HD Audio
- Maximum Compatibility: VGA Card length: 440mm / PSU length: 180mm / CPU cooler height: 160mm
- Package Dimensions: (W) 270mm x (H) 444mm x (D)558 mm
Only £186.95 inc VAT.
ORDER NOW
Lian Li PC-V700WX Midi Tower Windowed Case - All Black Mesh @ £219.98 inc VAT
- Windowed Case
Only £219.98 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
- Net Weight: 2.4KG
ORDER NOW
- Net Weight: 2.4KG
ORDER NOW
- Net Weight: 3.3KG
ORDER NOW
- Net Weight: 3.3KG
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
- Windowed Case
ORDER NOW
