New Lian-Li Cases
19 Feb 2010
Nottingham
Liani-Li are getting involved in some new-styled cases at last, that might actually be usable day-to-day:
Lian Li Shows Off PC-05, PC-06, and PC-07 Case Prototypes
by btarunr
Friday, September 26th 2014 11:49 Discuss (1 Comment)
Lian Li showed off prototypes of its new breed of cases, which can be used either as flat-bed open-air cases, or as towers. These include the mini-ITX PC-05, the micro-ATX PC-06, and the ATX PC-07. Their design is extremely simple. A tub-shaped metal structure holds key PC components along its tray, while a clear acrylic panel tops it off. You can either place the case flat-on, making it an open-air case with its clear-acrylic panel removed, or you can place it along its side, to resemble a tower. The three feature a forward-oriented standard ATX PSU bay, a slimline optical drive bay, two or more 3.5-inch/2.5-inch drive bays, and a PCI-Express 3.0 x16 riser, letting you install a graphics card. Lian Li is seeking feedback that will help it perfect the three. Leave them in the comments.
Link to TechPowerUp article
All round fail.
06 and 07 can only use a single expansion card because of the riser, and look like there's length issues if that card were a GPU because of the drive cage in the way.
05 also has its expansion card length severely limited because there's a bloody PSU in the way. And again it looks like a full-fat ATX PSU, which is totally redundant if you can only fit something like the SFF Asus and Sapphire GPUs.
All 3 have godawful airflow, limited space for air coolers and no provision for AIO water.
Total fail in all regards.
I like them a lot, would make for a nice feature HTPC rig. Needs some work and finishing touches but good effot for making something a little different from the norm.
Looking at the other pictures in the article it looks like they're almost open air even with the acrylic roof/side on.
