** NEW LIAN LI OFFERINGS **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
Small seems to be the way things are going at the moment.
I saw these unique looking cases at CeBit this year and was amazed at the designs as well as the use of space and innovative features.
Typically with Lian Li cases, the finish and overall appearance is ultra premium.
These are perfect SFF cases for anyone looking to be different with their installation. A real talking point.
Lian Li PC Q30A Mini Tower Mini-ITX Chassis - Silver @ £99.95 inc VAT
The new Unique Case from Lian Li, sporting a massive 140mm fan to exhaust hot air out and new innovative airflow techniques... stand out!
Features:-
- The 140mm exhaust fan in the rear to draw the hot air out.
- Curve Design! Simple and Clean design. Using 3mm aluminium panels formed with and hair-line brushed anodized aluminium finish.
- HDD / SSD Space
The modular HDD cage, are using thumb screws with rubber suspension, It supports four 2.5? drives.
Specification:-
- Model: PC-Q30
- Case Type: Mini Tower Chassis
- Dimensions: (W) 223mm (H) 357mm (D) 300mm
- Color: Black(Internal Black)
- Silver: Front bezel Material Aluminum
- Side Panel: Aluminum
- Body Material: Aluminum
- Net Weight: 2.13 kg
- 5.25" drive bay (External) None
- 3.5" drive bay (External) None
- HDD bay: 2.5" HDD x4
- Expansion Slot: 2
- Motherboard: Mini-ITX
- Mini-DTX
- System Fan (Rear): 140mm Fan x1
- I/O Ports USB 3.0 x 2 / HD Audio
- PSU USB 3.0 x 2 / ATX PSU (Optional)
- Maximum Compatibility
- VGA Card length: 200mm
- PSU length: 125mm
- CPU cooler height: 130mm
- PSU: SFX PSU (Optional)
Only £99.95 inc VAT.
ORDER NOW
Lian Li PC Q30X Mini Tower Mini-ITX Chassis - Black @ £99.95 inc VAT
Features:-
- Curve Design! Simple and Clean design. Using 3mm aluminum panels formed with and hair-line brushed anodized aluminum finish.
- HDD / SSD Space
The modular HDD cage,are using thumb screws with rubber suspension,It supports four 2.5? drives.
Specification:-
- Model: PC-Q30
- Expansion Slot: 2
- Mini-DTX
- PSU length: 125mm
ORDER NOW
Gallery
for people looking for small desktop footprint is is ideal
shows off hardware well and looks totally unique.
i didnt like it so much when i saw it in the metal but the shape and style has grown on me the more I see it
next week hopefully
We also have these on pre order within the next ten mins or so
lead time may be a little longer.
Lian Li PC-Q27B Mini-ITX Cube Case - Black @ £54.95 inc VAT
Sleek and tiny the new Lian Li PC-Q27! And despite the extremely compact dimensions proves to have features from all over, even with the ability to install a standard ATX power supply!
In fact, normally the Mini-ITX systems do not allow a large customization, forcing the use of proprietary solutions. In this case the Lian Li instead leaves scope for end-user customization and its needs!
The case is all aluminum, finish and quality of the materials are top notch, as usual with Lian Li. The weight is extremely reduced (2.1 kg) but this does not affect the robustness of the product, thanks to a solid structure. The brushed aluminum surface is extremely stylish and not out of place in a modern living room!
Specification:-
- Material: Aluminum
- Color: Black
- Form Factor: Mini-ITX
- Expansion Slots: 1
Fan (optional):
- 1x 120/140 mm (bottom)
Drives:
- 1x 5.25 inches (external, alternative use as an internal 3.5-inch bay)
- 1x 3.5 or 2.5 inch (internal, front)
- 1x 3.5 or 2.5 inch (internal, bottom, only without fan)
- Power Supply: Standard ATX
I / O Panel:
- 2x USB 3.0
- Maximum PSU length: 180 mm
- Maximum CPU cooler height: 70 mm
- Maximum cards Length: about 195 mm
- Weight: 2,1 kg
- Dimensions: 200 x 300 x 240 mm (W x H x D)
Only £54.95 inc VAT.
ORDER NOW
Lian Li PC-Q27A Mini-ITX Cube Case - Silver @ £54.95 inc VAT
Specification:-
- Color: Silver
Fan (optional):
Drives:
I / O Panel:
- 2x USB 3.0
- Weight: 2,1 kg
ORDER NOW
love the shape don't like the metal finish thou looks like it should be hanging from the ceiling,air conditioning.
Rjkoneil will this be the only 2 finishes that they do or is there more color schemes to follow.(Q30A)
I thought of an old gas fire when I saw the first picture but it's starting to grow on me now.
I'm not sure I like how the front of the case overhangs at the top but with a bit of modding and a 120mm rad on the back things could be quite interesting :p I'm thinking one of these would look pretty sweet with an cylinder res mounted externally on the side.
