- 3 Mar 2020
Lian-Li are back with a new Mini-ITX Case, the Q58. Part of an extended range, this chassis has an amazing 14.5L capacity, for all your premium gaming hardware. Many aspects of this case have been curated to support detail orientated builds, as well as ease of use. The side panels are hinged, splitting in the middle to provide ample access to the interiors when installing hardware. As standard, these panels are tempered glass for the top half and aluminium mesh for the bottom half. However, they are hot-swappable meaning you can arrange them any way you like.
With its compact design yet enormous versatility, cable management and innovative features help to keep this case as sleek and efficient as possible. The interior is armed with plenty of Velcro straps and tie-downs for taming cables, whilst many of the features negate the need for extra cables. Behind the Lian Li logo panel on the back, there is a header hub for PWM fans and LED strips. Containing three of each, this interfaces directly with the motherboard and can be controlled via the software you would use to control that hardware.
Granting you great flexibility with your build, there are several modular aspects to the Lian Li Q58, in addition to the hot-swap panels. Included within the contents are a PSU ATX bracket and HDD expansion rack, for adjusting support to accommodate larger hardware.
Lian Li Q58X3 Mini-ITX Aluminium and Tempered Glass Case - Black @ £104.99 inc VAT
Mini-ITX case, Aluminium, Tempered glass, Hot swappable features, Modular, Integrated fan and LED header hub, 3 expansion slots, Black.
Only £104.99 inc VAT.
ORDER NOW
Lian Li Q58W3 Mini-ITX Aluminium and Tempered Glass Case - White @ £110.99 inc VAT
Mini-ITX case, Aluminium, Tempered glass, Hot swappable features, Modular, Integrated fan and LED header hub, 3 expansion slots, White.
Only £110.99 inc VAT.
ORDER NOW
Lian Li Q58X4 Mini-ITX Aluminium and Tempered Glass Case - Black @ £136.99 inc VAT
Only £136.99 inc VAT.
ORDER NOW
Lian Li Q58W4 Mini-ITX Aluminium and Tempered Glass Case - White @ £136.99 inc VAT
ORDER NOW
Lian Li Q58X1 Mesh panel for Q58 Mini-ITX Case - black @ £18.95 inc VAT
Additional side panels for Q58, Aluminium, Mesh, Black, Pack of 2, Hot swappable, Easy installation
Only £18.95 inc VAT.
ORDER NOW
Also In white
Lian LI Q58W1 Mesh panel for Q58 Mini-ITX CASE - white @ £18.95 inc VAT
Lian Li Q58X1 LED Strip Kit For Q58 Mini-ITX Case @ £18.95 inc VAT
LED strip kit, For Q58 Mini-ITX Cases, Side diffused, 3-pin 5V header, Connects to header hub.
ORDER NOW
Also in White
Lian Li Q58W2 LED Strip Kit For Q58 Mini-ITX Case @ £18.95 inc VAT
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
Also In white
ORDER NOW
Also in White
