New Lian Li ????
25 Aug 2005
New Lian Li Case?
RC
Yeh not one I've seen before.
Looks old due to the classic design of it. Plus it actually has a proper motherboard tray! which none of the other current Lian Li's have as far as I know.
I quite like it :)
Wouldn't be much cop for cooling though.
I quite like it but im suprised about the rear mounted PSU. It was hard getting a cooler for my V600, and the A05 (i think) has a much nicer layout with it at the front.
Could be server aimed? Would explain the cruddy cooling and odd PSU placement. Not many HDD trays though. What would need a load of 5 1/2 bays? Aimed at DVD pirates? :p
I'll stick with my G50 thanks.
PK!
same here :)
and as for coolers there plenty of options for it if you know what you're looking for. Currently using an s939 opteron heatsink with inverted fan (x2 4200+ 89w idle 25C) but will be changing for a nt06 (passive like the sugo sg01e)for less noise as I know that will fit from measurements between my sugo sg01e and g50.
