Hey everyone
i wouldn't say i was a pro WC loop expert, but i have built 2 loops for my last 2 builds, my current case ( NZXT Switch 810 in white ) has a fault, so ive sent it back to the e-tailer for replacement or repair
i currently have
1 x 240mm Ek XT rad
1 x EK HF supreme block
1 x XSPC 5.25 bay res pump combo (750l ph)
4 x fractual design 120mm 1000rpm fans push pull config
what i ideally want to do when i get my case back, is expand my look as im changing the asthetics of the build around.
heres what i looked like before i sent the case back
Now im scrapping the orange, already sold the cables and getting white or black nzxt braided ones
my question to you guys is
i want to add a 360mm rad into the loop, i run an i7 3770k, and i like to overclock, probs 4.8ghz 24/7, my temps border around 70 degrees now @ load with my current setup but i want to drop them slightly for more benchmarking headroom
I might add a gpu loop in at some point in the next 6-12 months but my cards cooling is fine atm and the waterblock needed is custom ordered from america i believe.
heres what im thinking
1 x 240mm Hardware Labs Black ICE Radiator GTS-Lite 240
1 x 360 Hardware Labs Black ICE Radiator GTS-Lite 360
1 x XSPC Res pump combo ( current one im using )
1 x Bay res somewhere visible, i love the look of them, got a mod planned when my case comes back
would this lower my temps? and i need fans to go with them, probs get more fractual design 1000rpm's for push pull on all the rads as they are pretty quiet
what do you guys think?
i currently have
1 x 240mm Ek XT rad
