New Loop; Parts required?
19 Nov 2011
Hey guys,
I have decided I want to go for a custom loop, but to be honest I have no idea where to start. Basically I am looking for a CPU only loop for now, but what will give me better temps than my H100i.
My current system specs are:
i5 4670k @4.4ghz
16GB of RAM @2400mhz
120GB SSD
Corsair 750w PSU
Corsair Carbide Air 540
I'm hoping for something around the £160 mark if possible?
Thanks for any help in advance
This is the sort of loop you're gonna get for £160. If you want to add to the loop, you may want to consider increasing your budget.
YOUR BASKET
1 x XSPC EX240 120mm Radiator - Black £37.99
1 x EK Water Blocks EK-DCP 2.2 X-RES £34.99
1 x EK-Supreme LTX - Acetal CSQ Intel CPU Waterblock £29.99
1 x EK DCP 2.2 Pump (12v) £29.99
1 x Primochill Primoflex Advanced Tubing 13/10 - Clear £5.99
1 x Mayhems Ultra Pure H2O Watercooling Fluid 1L £4.99
6 x XSPC G1/4" to 3/8" ID, 1/2" OD Compression Fitting (Black Chrome) £2.99 (£17.94)
Total : £171.47 (includes shipping : £8.00).
You might not get better temps with a cheap loop depending on what is holding your processor back.
Is it delidded? Also, don't forget radiator fans!
