New machine
20 Jan 2005
At my PC
Looking at treating myself for Xmas :D, just knocked up the below as a draft spec:
- Asus P5W DH Deluxe (Socket 775) PCI-Express DDR2 Motherboard
- NEC MultiSync® LCD20WGX2 20.1" Widescreen LCD Monitor
- Creative Sound Blaster X-Fi Xtreme Music
- WD Western Digital Raptor 150GB WD1500ADFD 10,000RPM SATA
- OcUK Silentmaxx Aluminium Hard Drive Enclosure
- Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz
- GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2
- Scythe Ninja Plus Rev.B Heatpipe CPU Cooler
- Pioneer DVR-111BK 16x16 DVD±RW Dual Layer ReWriter
- GameXStream 700w Silent SLI Ready ATX2 Power Supply
- Connect3D ATI Radeon X1950 XT-X SILENT Heatpipe 512MB GDDR4 AVIVO TV-Out/Dual DVI (PCI-Express)
- Case - Akasa Eclipse 62 Aluminium Case
Any bad experiences with the above or any recommendations?
Cheers
If you want to save a bit of cash then swap the Raptor for a Seagate 7200.10. You could get a bigger HDD for less than that Raptor and would'nt be too far away in performance wise , otherwise that spec looks sweet.
Yeah, thought about that but I have an external drive for extra stuff + a 120GB Samsung Spinpoint spare so the raptor should be sufficient, and quick.
One thing I haven't looked at much are quiet 120mm case fans for the Eclipse. Can any Eclipse owners out there recommend quiet case fans?
Cheers
