New Machine
7 May 2009
Hi everyone,
I'm building a new gaming machine and I've pretty much got all the specs sorted out except the case, although im still unsure of whether i should get i7, I will be Oc the q6600.This will be my first gaming machine build. :D
At the moment the specs are:
Intel Core 2 Quad Q6600 2.40GHz (1066FSB)
Asus P5Q Pro Intel P45 (Socket 775)
OCZ Blade 4GB (2x2GB) DDR2 PC2-6400C4 Dual Channel
2 Sapphire ATI Radeon HD 4890( Crossfire)
OCZ ModXStream Pro 700w PSU
Samsung SpinPoint F1 RAID 320GB SATA-II 16MB Cache
Any case which will hold all of these components snuggly is good for me, don't mind if its large better for future upgrading. All suggestions are valued. ;),sorry if i missed anything out. :)
Thanks,
Hey,
What size is your current monitor, as it might be worth you getting a 4870X2 since OCUK have an amazing price on these £248. Lastly what's your budget?
Currently the Q6600s are overpriced and pointless. The choise for a C2Q are really a Q6700 or a Q9550 or getting an i7 920 D0.
From what you have posted and also depending on your budget, there are a couple of changes that I would make:-
  • Swap the Q6600 for a Q6700.
  • Swap the PSU for a Zalman/BeQuiet 600/650.
  • Swap the pair of 4890s for the 4870X2
  • If overclocking you would need an aftermarket cooler, such as this Titan Fenrir
Case wise, are you looking for cooling performance, or a sleek and subtle case? You can't really go wrong with cases, all done to individual choice, my current favourite is the Silverstone Fortress.
If you are wanting to go i7 then you would be mad not to get this, cheaper than if you bought the components separately and comes with a guaranteed overclock!
*OVERCLOCKED* Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz @ 4.00GHz / Gigabyte EX58-UD5 Intel X58 Motherboard / Kingston HyperX 6GB 12800C9 1600MHz DDR3 Bundle
Representing the cream of the crop of today's bleeding edge performance hardware, OcUK's 'Extreme Bundles' are selected to satisfy the needs of the most demanding enthusiast.
OcUK Overclocked Bundles feature carefully selected components tested to assure compatability & stability, guaranteeing the integrity of the overclock.
We worry about the fiddling and tweaking, you just enjoy the performance.
This bundle ships pre-built and pre-overclocked direct from our Technical Department. All you need to do is attach the CPU cooler and power it up.
- Maximum Speed
- Maximum Stability
- Maximum Compatibility
- Maximum Overclocking
This Bundle contains the following components:
1 X Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz (Socket LGA1366) - OEM
1 X Gigabyte EX58-UD5 Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
1 X Kingston HyperX 6GB (3x2GB) Intel XMP DDR3 12800C9 1600MHz Tri-Channel Kit (KHX12800D3K3/6GX)
1 X Titan TTC-NK85TZ Fenrir CPU Cooler
1 X Arctic Silver 5 Thermal Compound (3.5g)
£589.98 inc VAT.
BUY NOW
Benchmarks coming soon, but from the clock speeds and user reports it is easy to see that the performance is something special!
Thanks for the quick response, A friend recommended the q6600 to me, i thought it was quite expensive compared to the capabilities of an i7, the reason i wanted to get 2 4890s were from various extensive benchmark tests bringing that trumps over the 295 GTX lastly my budget ranges 1000-2000GBP(pound sign doesn't work on my current pc :p)
Edit: My current monitor is a 22 inch samsung cant remember which resolution/model, in a few weeks i will be upgrading to a 30 inch monitor
The Q6600 was and still is a brilliant chip, however now it doesn't make sense to buy it new when the faster Q6700 2.66Ghz is £35 odd less. Well based on your budget, I'd go with the i7 bundle with either the 4870X2 (95% as quick as a GTX295 for £100 less) or Xfire 4890s, with a case a reasonable cooling of your choice.
The Q6700 is faster and cheaper - the 6600 just has a good reputation.
The 6600 was a good buy when it hit £100, for current prices it's just an average chip - you'd get better performance for less cash with an AMD 940BE or even a 720BE, the 720 nearly matches the 6600 for performance, especially in gaming, and is £30 cheaper before you even look at the motherboard.
The Antec 1200 looks most likely to be purchased :D, Lian-Li style 1200 is too huge for my liking lol, second contender would be the Coolermaster RC-1000 Cosmos Silent Full Tower Case - Black (No PSU)
This has used Most of your Budget, but includes a Brilliant Case, and full water cooling. I only choose this case because the Black one with the window isn’t in stock or even listed anymore. I chose the Retail version of the CPU, as it is only ~£5 more and has a game and longer warranty with it. And I THINK the HD4870 water block works with the 4890. I just included 10 barbs as a rough number; I don’t know how many it will need. And you will have to get the Coolant from somewhere else as there is none listed. I know Quite a few things on the list are out of stock, but this is a rough guide for a Top dollar water-cooled PC. Also the Water-cooling items will probably need rethinking, as I’m not an expert at water-cooling.
Thanks,
Ripped
To add to Ripped's spec:-
I would add some extra fans to use on the rads, and to double check whether a 4870 block will fit a 4890, swap the paste for MX-2 (similar temps if not better, easier to spread and doesn't have a 'bedding in period').
Apart from:
2 Sapphire ATI Radeon HD 4890 1024MB GDDR5 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
Antec 1200 Twelve Hundred Ultimate Gaming Case - Black (No PSU)
LG GGC-H20L Blu-Ray Reader & HD-DVD ROM Serial ATA Drive - Retail
what else will i need, minds blank at the moment :D
Hard drives, Sound card, 650/750W PSU, Mouse and keyboard, Monitor, speakers, X64 Operating System (though you can use Windows 7 x64 for free for the best part of a year).
Thanks:D, ill probably be using windows 7 x64 till the systematic shutdowns
Edit: My Current Basket(Excluding the water cooling)
OCZ ModXStream Pro 700w Silent SLI Ready ATX2 Modular Power Supply
Asus Xonar D1 7.1 PCI Sound Card (90-YAA0B0-0UAN00Z)
Western Digital Caviar Black 640GB SATA-II 32MB Cache - OEM (WD6401AALS)
Saitek Eclipse III Gaming Keyboard with Multi-Colour Backlight
Razer Diamondback 3G Frost Blue 1800dpi Gaming Mouse - Retail
