hello
i have four memory sticks
1gb corsair value select (ddr 400)
512 mb corsair value select (ddr 400)
512 twinmos (ddr 400)
and 256 mb corsair value select (ddr 266) - this is only being used to help me test the system
anyway, i have an av8 socket 939 mobo. it has four ddr slots:
I had the two 512mb's in slots 1 and 2:
it worked
but i can't get 512 + 512 + 1gb to work. the best ive got is:
if i do other combinations (even with the 256 stick) it just bleeps and nothing is displayed on the screen.
here is a "table" of some of my "results". none worked apart from 2:
512twn = twinmos
512cor = corsair value select
ANY IDEAS?
I thought maybe its to dowith dual channel. i cant find an option in bios to turn dual channel off though...
cheers
Code:
1 2 3 4
Code:
512 512 / /
it worked
Code:
1gb / 512 (corsair) /
512twn = twinmos
Code:
1gb 512twn / / nope
1gb / / / nope
1gb / 512cor / YES!
1gb / 512cor 512twn nope
1gb 256 512cor 512twn nope
/ 256 512cor 512twn nope
/ / 512cor 512twn YES! (running it now)
512cor 512twn / / YES!
ANY IDEAS?
cheers
