- 13 Sep 2003
- Doncaster
Just bought a SanDisk Ultra Flair 32 GB USB 3.0 stick and been testing it with crystaldiskmark and usb flash benchmark, with both giving similar results. That is, when I first plug the stick in, I get results about one third of those expected. If I then physically remove (software eject first) and insert it in the same socket, then re-run the benchmark, I get about the expected/rated speed. I don't know if its normal behaviour or if there's a problem, but obviously I don't want it defaulting at the lower speed if I need to use it for a bootable/install Win10 O.S (its main purpose).
(Running the benchmark twice without removing the stick gives the same slower result)
First time plugged in
Second time
thanks
joe
Second time
thanks
joe
