New Mini Me case Waht to get Help
9 May 2009
Hi all
I am going to be building a new computer soon and wanted some advice on a small case as I am going to build a small computer as in the past I have always used large cases so I have posted some links down below to see what you think and what would you go for
The older model:UMX1S not to be mistaking for the Newer :UMX1 Plus as I think the newer version has stepped back in design on the inside
http://jonsbo.com/en/products_21_1.html
The U3BK
http://jonsbo.com/en/products_18_2.html
Node 304
http://www.fractal-design.com/home/product/cases/node-series/node-304-black
Lian Li PC-Q25B
http://www.lian-li.com/en/dt_portfolio/pc-q25/
Phenom Micro-ATX
http://www.bitfenix.com/global/en/products/chassis/phenom-micro-atx#specs
any thoughts to these cases or is there anything you think is better can anyone help make my mind up as I just can not decide
thanks for any info or input
Asus Motherboard With Intel i7
Seasonic PSU Modular
32gb Memory
1 SSD and 2 x 3.5 Drives in the future possible 3 SSD and no 3.5 drives
A GFX card have not made my mind up on what type yet but needs to run 3 x 1200 res monitors and maybe higher res monitors in the future
External Bluray Drive using USB
thanks
i have a jonsbo u3, love it to bits. Shame OcUK do not stock them, they are incredibly good value for money.
lian li build quality with thicker aluminium.
the only gripe i have with it is that it only supports gpu of 260mm length. i bought a Msi GTX 970 (267mm) over xmas and it can only be installed without the outer shroud. I returned it and bought EVGA 970 from OcUK (when it was £252 w00t). fits perfectly.
overall, a brilliant small footprint MATX case.
