New Moniter advice
8 Feb 2006
UK
Hey guys goin to buy a new moniter in the next incomming weeks. I have a budget of £700. Does anyone have any idea on what moniter i should get except the dell 2407wfp and 30" model, as i heard that it have some issues, and it also has to be hd and around 24". If anyone has any suggestions i would much appercaite it.
Thanks Pajaman
what do you mean it has to be HD?
are you looking to get a HDTV LCD which can also act as a monitor?
if you are getting a dedicated LCD monitor then it will be HD already as the resolution is massive on big monitors!
so you want one with HDCP support? There aren't really many models out with this support at the moment, the BenQ FP241W is forthcoming (see the thread about it in this forum) and looks exciting.
With the arrival High Definition content, the IT industry has developed a new norm referred to as HDCP (High Bandwidth Digital Content Protection). This is a means of potentially overcoming piracy and is a protection algorithm used for future HD content including Blu-Ray and HD-DVD. For this to operate, the source (e.g. DVD), graphics card and monitor would all need to have HDCP compatibility in order for the source to be viewable. Monitors which are HDCP certified also include a digital interface as this is inferred by the technology. HDMI and / or DVI connections must be present for true HDCP certification. If this HDCP certification is not present in all elements, the image is likely to not be displayed at all, and you will see only a blank screen or perhaps some very intrusive “warning” messages.
this article at BeHardware is interesting too
