New monitor advice for mac mini
19 Jul 2006
My current set up is a Pc and I have 2 iiyama PL2202W (21.5") monitors set up.
I mainly do coding and web dev, I don't really spend that much time in Photoshop so exact colour recreation is not to important. The resolution is 1680x1050. I like the dual screen workflow that I have as my PC has two outputs and can handle this.
However I am looking at getting a Mac Mini as well that I am wanting to use at the same desk and just switching a cable or using a switch to change devices.
Would I gain anything from moving from my 2 screen display to something like
https://www.overclockers.co.uk/b-gr...ing-flicker-free-mon-mo-110-bq-bg-072-bq.html
or https://www.overclockers.co.uk/b-gr...descreen-led-monitor-black-red-bg-085-bq.html
If your monitors have multiple inputs you can have the pc and mac mini pluged in and just change input using the monitors settings. I have my laptop and mac mini pluged into my second screen and just change input to switch.
