New Monitor Advice
23 Mar 2018
Current PC Spec - i7 6700k - 16gb 3200 ram - m.2 hard drive - Asus Hero V111 Hero MB
I will be buying an Nvidia GTX 1070 or 1080
Games - F1 - Dirt4
Looking for a monitor at 27 inches, totally confused with so much on offer. Hellllllllllllllp
is gsync important to you? if you haven't experienced it you may want to consider if you want to spent extra just for the gsync premium. Many would say that you have to get it but the problem is that it adds another 200-400 pounds to the monitor and if you haven't experienced it you don't miss it either :) worth considering. You can get so much better monitor specs for 600 if gsync isn't important to you.
LG 34UC79G - 34" 2560x1080 144hz ultrawide IPS (supports freesync if you ever happens to get an amd card in the future, not that it matters now)
LG 34um88C - 34" 3440x1440 60hz (most can be pushed to 75hz or more) ultrawide IPS(supports freesync, again doesn't matter now)
Dell S2716DG - 27" 2560x1440 144hz 16:9 TN, supports gsync.
Dell S2417DG - 24" 2560x1440 144hz 16:9 TN, Supports gsync(i would pick this over the s27, i have had both and the s24 is slightly better. It also doesnt look like a tiny 24inch to me which i find weird)
Just a quick list. Im sure i can find more if i think about it.
