New Monitor Advice
10 Aug 2009
Malvern
Hello, Just recently got a GTX1660 TI and now looking to upgrade
my viewing from a TV to a monitor.
Around £300 - 350 is my max budget.
Looking at my hardware what would you advise, I would like to go 2K
and 144HZ but I know my card would struggle a little,
but I wanna try a higher resolution and more frame would be nice
Im only a casual gamer nowadays (mainly FPS) but still like pretty graphics
and smooth gameplay.
Thanks , Kev
Hi
You should be good for 60fps at 2k with most fps with high settings enabled i would say and from looking at videos like this on YouTube with a similar setups
to yours will give you an idea of what to expect in terms of frames.
https://www.youtube.com/watch?v=k73fqeIp1Fs
While your not going to max your monitor out with that card you will still notice the extra smoothness a 144hz monitor gives and the extra desktop space at 2k is nice too have.
Something like this would be ideal.
https://www.overclockers.co.uk/acer...r400-widescreen-gaming-monitor-mo-14b-ac.html
Thanks for the links, very helpful,the monitor looks just great, looks like lots of experimenting
with settings, which should keep me entertained for a while !!
