Hi all,
I ll try to keep this a bit straightforward because me personally it got me really perplexed
Relevant specs: Asus dark hero, 5950x, 780Ti, and upgrading to the AW2721D from an old Korean monitor (you'd remember them if you were around in 2013).
So pc was up and running, disconnected old monitor, connected the new one, all good, used the pc for a while, no issues.
Tried to re-start.
Wouldn't post. I think it was getting error 98 or something like that. Tried a few times, no bueno, sometimes it felt that it was doing a re-train of the memory and I assume it would try to get into safe mode but obviously I couldn't see anything.
Connected older korean monitor (DVI). All ok, into bios ok etc, went into windows. Re-connected the alienware one, looked ok. Restart, same issue. I did some browsing online and connected the monitor through HDMI. Shows bios and boots fine (however obviously gimped as it's an HDMI which is slower - in this case).
If I recall I tried at some point to re-connect through the DP and it wouldn't hang on the error anymore and did get to windows (still wouldn't show bios), and even though it would go to the 9E code which is the final one, the VGA led light (the white one, whichever that one is) on the MB diagnostics would stay lit up.
Did some more browsing, went into bios, enabled CSM LEGACY mode, and under "Boot from PCI-E/PCI expansion devices" I switched from Legacy to UEFI.
Restarted and then was able to see and access the bios just fine.
So my main question is basically... WHY????? I can't imagine that this is a default behaviour and I am really perplexed as to how a peripheral like a monitor can literally break a boot sequence.
Tried to re-start.
