1 Jul 2011 at 10:45 #1 Enaver Enaver Associate Joined 15 Oct 2010 Posts 63 Just got my new setup and now i want to upgrade my screen. Ive been looking at the Dell U2311H. Just wondering is there any other ones you lot would recomend?
1 Jul 2011 at 13:16 #2 Nursi88 Nursi88 Associate Joined 9 May 2011 Posts 39 The Dell U2311H seems to be a solid choice. Another is the LG W2363D. I'm currently deciding between the two but leaning towards the Dell. Some threads to check out: http://forums.overclockers.co.uk/showthread.php?t=18274348 http://forums.overclockers.co.uk/showthread.php?t=18284824
1 Jul 2011 at 14:05 #3 Enaver Enaver Associate OP Joined 15 Oct 2010 Posts 63 Aye came across them posts 1 hour or so ago. Ive gone for the LG even though i was leaning towards the Dell. Should arrive tomorrow so hopefuly its good. Either way it will be 1000x better than what ive got atm.
10 Jul 2011 at 22:43 #4 secondsight07 secondsight07 Associate Joined 10 Jul 2011 Posts 30 Enaver said: Aye came across them posts 1 hour or so ago. Ive gone for the LG even though i was leaning towards the Dell. Should arrive tomorrow so hopefuly its good. Either way it will be 1000x better than what ive got atm. Click to expand... Can you post your opinions on the W2363D?
