So I'm looking for a new monitor to replace my current one (a Dell Ultrasharp 2407WFP-HC 24") as there's no HDMI inputs on it, and the power socket in the monitor is starting to go. As the thread title says I'm looking to use the monitor for PC and PS4 gaming. Also for movies and work.
I'm looking at the Dell UltraSharp U2414H 24" Widescreen LED Slim Bezel Monitor as I like the look, my current Dell monitor has lasted since 2007, and it has 2 HDMI inputs. Also the display ports might prove handy.
The graphics card I'm using is the SAPPHIRE HD 7950 3GB GDDR5 (11196-00) if that makes any difference.
So should I get this monitor or is there a better one that you guys think I should go for? Just to note for any suggestions, I want a monitor with 2 HDMI inputs, so I can plug both my 360 and PS4 (when I get it) into it, and I don't want anything larger than 24" really, as it wouldn't fit on my desk
. Also if anyone has that monitor, to connect it to my speakers I just need a 3.5mm male to male audio cable right? Something like this (as OC doesn't seem to do them). If I decide to hook my PC up to a monitor using the HDMI cable, would this one be OK?
Thanks.
. Also if anyone has that monitor, to connect it to my speakers I just need a 3.5mm male to male audio cable right? Something like this (as OC doesn't seem to do them). If I decide to hook my PC up to a monitor using the HDMI cable, would this one be OK?Thanks.
