Hello everyone,
I'm new here so please don't judge if the format of my thread isn't the best.
So today i bought a new monitor. The monitor is Samsung Odyssey CRG 24" 144hz. I've been using this same model before this one and it was working perfectly fine from the moment i plugged it in, unfortunately i had an accident and it fell and broke. So i bought a new one because i liked the model.
But upon installing it and plugging it in i realised the screen wasn't the same. So i tried looking into the settings of monitor and didn't yield any results sadly. My problem is , as said in the thread title, i have these shadow pixels on small icons and letters almost as if it's not a native resolution and something got mixed up.
Specs of my pc are as following:
Motherboard: Gigabyte b460 HD3
Cpu: Intel core i3-10100f 3.60GHz
GPU: Amd radeon Rx 570 4GB
Ram: HyperX 16gb Fury ddr4 2666 mhz
The cable that i use to connect my monitor is HDMI 2.0 and its working perfectly fine (i've tested it with other stuff) the power cable of the monitor also works just fine since i tested it with the old monitor too.
That's about all i can say from my knowledge. Any help is really appreciated!
