New monitor query..
Si.
Si.
22 Oct 2002
Melbourne, Aus
After 8 years I’ve bought myself a new monitor..Gigabyte - M32U
im not sure if it’s working as expected. Games are showing 120fpS in software, but the monitor it’s self is showing 60fps.
how do I know how many FPS I’m actually seeing?
if the GPU is generating 120 it doesn't mean the screen can show this.
also i see it 144hz @ 4k you would have to use the right port on the GPU only 1 of them will be capable of going to this FPS @ 4k.
i had the same this with my 165hz 1440p, it was capped at 120hz till i used the right display port.
what GPU do you have
It's a 4070ti, using HDMI and there is only 1 HDMI port, seems to be working fine now I've changes the windows settings.
Seems like you got the answer, but try switching back and tell me you can't feel' the difference :D 60Hz feels like playing through treacle after using 120+ for a while, even in windows just navigating menus for that matter.
