Hi everyone.
I’m looking at getting a new monitor.
It will mainly be used for watching BluRay/Netflix/Sports and some gaming World of Warcraft, Obduction when released but thats about it currently.
I have several 3D BluRay’s lying around that I have never seen so I am considering that.
I am also considering a 29” Superwide.
My current GPU is a GTX560Ti in a Rampage Formula, would I need to upgrade the Graphics card as well?
The monitor is the most important and I have a budget of £300 for it.
So that gives us:
3D:
https://www.overclockers.co.uk/asus...d-widescreen-led-monitor-black-mo-040-as.html
Superwide:
https://www.overclockers.co.uk/asus...e-led-multimedia-monitor-black-mo-064-as.html
https://www.overclockers.co.uk/asus...m-bezel-led-monitor-black-with-mo-063-as.html
Which of those would you guys recommend, should I go Superwide or 3D and would I need to upgrade my GPU?
If I do could you recommend an upgrade. It doesn’t have to be the best, just an upgrade that allows me to use the new monitor, of course if it allows me to play the latest games then great. AMD or Nvidia.
Many thanks.
So that gives us:
3D:
Superwide:
Many thanks.
