New Monitor Required
28 Jun 2009
Łódź, Poland
Hi there,
So, i've currently been using an AOC G2460PG monitor for the past 5 or so years, and it's developed two white/faded horizontal lines at the top and it also developed a dead pixel within a month of owning it.
I've put up with the lines to begin with for 2-3 years as they were barely noticeable, but now it's getting worse and i've read that this is an issue with the monitor itself and i've also tested on other monitors and they show no symptoms, so new monitor required.
I'm after a monitor at 24/25 inches, 1920x1080 with G-SYNC or G-SYNC compatibility (preferred for flexbility if i go for an AMD GPU in the future).
I have checked out the HP OMEN X 25F but i think it would be a good idea to get various opinions from other people who maybe own a monitor similar to what i'm after or at least know good monitors on the market, but budget wise would be £350 or lower (if possible).
Such small medieval resolution monitor shouldn't be budgeted even £200...
I mean there are 144Hz 27" 2560x1440 VAs around £260 and:
https://www.overclockers.co.uk/aoc-...een-led-backlit-gaming-monitor-mo-057-ao.html
And IPS for £360...
https://www.overclockers.co.uk/acer...r400-widescreen-gaming-monitor-mo-14b-ac.html
Unless having very tiny table would recommend actual upgrade.
That would be also big improvement to all PC use by actually being able to fit content into screen without constantly scrolling down and up.
