New monitor suggestions
5 Feb 2012
im looking for a new monitor as im not happy with my current LG flatron 23 inch w2361v, mainly because of the tilt issue, and i guess viewing angles as the colors change if im to far right etc. This one is 2ms, everything does look good so its not a BAD monitor.
But i just want something similar 23-24 inch max, with hdmi and dvi for my pc and xbox, for like max £180 but preferrably cheaper?
then id probably use this for my other pc or something down the line.
cheers
Sounds like you're looking for the Iiyama Prolite X2377HDS.
It has an IPS panel and thus better viewing angles than your current LG and the Samsung mentioned above. Has both DVI and HDMI and fits your budget although if you're in no hurry it might be worth waiting till OC UK comes up with a special deal for it.
