new monitor upgrade
28 Jan 2004
uk
hi there,
can someone please advice a good monitor for use with a nvidia m2000. Not a gaming rig, mostly photos and videos. currently using a samsung syncmaster 2253bw, sizewise same or slightly bigger, 25-27 max
thanks
Hi
The Dell 27" UP2716D should fit the bill its IPS so ideal for photos and video viewing and it 2560x1440 resolution will give you much more desktop space to play when compared to your currant monitor.
https://www.overclockers.co.uk/dell...440-ips-widescreen-led-monitor-mo-089-de.html
You don't say what your budget is so if you don't wish to spend so much then you can get a AOC 25" IPS 2560X1440 for under £300.
https://www.overclockers.co.uk/aoc-...creen-led-monitor-silver-black-mo-029-ao.html
Hi
Hi,
Is the AOC one height adjustable ?
Hi there
Monitor arrived today, I'm a bit confused on what cable type connection to use with my Nvidia m2000 quadriceps which has only 4 display ports outputs. Monitor has all the inputs incl hdmi 2.0. I'm using display port to display port at the moment but wondering if I go display port to hdmi 2 will give me any gains in quality?
hi guys,
i am now using the BenQ BL2711U with windows 10 pro, and left the display settings on default, do u reccomend altering the settings for a better viewing experience or leave them as they are?
reason im asking is that ive noticed sometimes blurred wordings in apps or webpages, most of the time is ok though, bit smaller in general but i can live with it. Any calibration required for this screen ?
