- 2 Apr 2009
Just got a new Samsung SyncMaster P2370HD TV/MONITOR and wanted to plug it into my PC:
PC spec is:
WINDOWS 10 64BIT
CPU: AMD Sempron 145 (SOCKET AM3)
GPU: Nvidia Geforce GTX 260 (x16 EXPRESS 2.0)
Motherboard: * MSA78L M/USB3, (x16 EXPRESS 2.0)
RAM: * 8GB DDR3 1333MHZ RAM *TRI-CHANNEL* 4x2GB KINGSTON
DVD DISC: * 22x SATA DVDBRÆNDER +/- OG DVD-RAM
PSU: * 550W "GAMING" STRØMFORSYNING, SILENT, 17DB
Hard Disc: * 1000GB SAMSUNG HARDDISK, 7200RPM, 32MB CACHE (1TERABYTE)
After conecting and powering up I'm using a HDMI to HDMI cable. My videocard is a Geforce GTX 260 Gainward, with DVI-I, HDMI, 15-pin connector D-Sub, adapter HDMI-> DVI included .
The picture is very distorted and the colors are flattened a lot. The text itself is only just about readable. Around all the text, is some sort of white marking. No matter what resolution I set it at, it remains and so do the bad quality.
The TV resolution is set to 1920X1080 running at 60Hz.
I have tried running at different resolution and refresh rates but still the same quality.
PC spec is:
WINDOWS 10 64BIT
