I've had an AOC Q3279VWFD8 monitor for years. 2560x1440, either 32 inch or 31.5 inch depending on how you measure it. IPS panel. 75Hz refresh. A decent monitor at the time and excellent value for money.
It might be on its way out now. It's developed a very small spot near one edge that's slightly brighter than the rest of the screen. Only visible on a light background. Not a problem. But it's a fault. I'm leaning towards buying a new monitor and keep this one as a backup.
I'm not looking at going to 4K because my PC (Ryzen 7 5700X, 32GB DDR4-3600, Radeon 7800XT) wouldn't be great for 4K gaming so if I bought a 4K monitor I'd end up spending more money on upgrades and I don't think it's worth it.
Main uses are gaming and watching videos on Youtube. Viewing distance is around a metre as I'm using it at a desk.
I'm after something about the same size as the monitor I'm used to. 27 inch would seem a bit small to me now, which is a bit of a shame as it seems that most 2560x1440 monitors are 27 inch.
Budget is <£400 because that's as much as I'm willing to spend on a monitor. That's a max, not a target. If there's a decent enough monitor with those specs for £200, all the better.
I know little about the current state of monitors and the normal nomenclature gets on my nerves. Alphanumeric string, often with several different monitors having almost identical names. Oh dear, you bought the Z32AJ197892HJ4BQ when you intended to buy the Z32AJ197892HJ4BP! How could you make that mistake? Bleh.
So yeah, I'm after advice.
