Hi I'm looking to get a new monitor to go with the pc I'm buying. The specs are as follows:
Asus p5n32-e sli+
Intel Core2Duo e6600 2.4ghz
Nvidia 8800gts
2gb 800mhz ddr2 ram (4x512mb)
Xfi Xtreme Gamer soundcard
Coolermaster realpower m520
I'm wanting to play cod2, cod4 and cod:modern warfare 2 when it comes out. I just read the sticky on native resolution for the different size monitors, and was wondering whether the above pc would be able to provide decent enough frame rates to run say a 22" monitor (1680*1050) or whether it would be better to go for a smaller monitor and run a more conservative resolution and thus better frame rates.
Budget is around £120 but am quite flexible if it's worth spending the extra doe.
Asus p5n32-e sli+
Nvidia 8800gts
..... so am I correct in thinking either the Asus or LG would be better?
