new monitor
26 Jun 2010
If you go for a second 22in (with the same resolution) I think you will be very happy - you will have loads more screen real-estate and moving from one to the other will feel much better than before as they are both the same size.
One thing you may want to consider is trying out an IPS monitor instead of just going for another TN. This one is the right size and resolution, plus it is a fantastic price considering the quality (here is an in-depth review).
