New monitor
7 Mar 2011
Oldham, Lancashire
I am now quite set on not using my TV for my new build, but getting a monitor for it, around 24". So any ideas? It will be used for gaming mostly, and coding but I may stick to my laptop for that so less so and powered by (probably) GTX 580. Up to say £300 but might go higher if it really is worth it.
Also, the 3d gaming thing with the glasses, is it really worth it?
3D gaming - probably not worth it. It's great on some games but personally, I'd wait for it to become more established before I'd invest. The other problem with 3d gaming is performance (twice the frames needed) but that shouldn't be an issue with a GTX 580.
If you're purely gaming on your build, and with a budget of £200, it might be worth investing in a 120Hz monitor anyway. Especially in FPS the smoother motion and lack of blur is brilliant. Sniping in BC2 at 120fps is quite an experience.
