After my "mitsubish diamond pro 2070sb" screen started to go on/off i have decided to upgrade to a new one but i just can't decide exactly which one to go for, i have a nvidea gtx680 card and use it for mainly playing RPG games EQ2, diablo 3 ect, and aslo zbrush and 3ds max, also i have aroud £400 to spend but may push to £500 if its needed to get what i want, a 27" would be nice too
hehe
Now i was alwasy under the impression that the lower the response time the better thats why i was thinking of getting a 120hz one like this one but reckon ill not use 3d that much:- http://www.overclockers.co.uk/showproduct.php?prodid=MO-033-AS&groupid=17&catid=1120&subcat=
But after reading loads of reviews n stff i think am liking this, but the 5ms is making me waver on it:-
http://www.overclockers.co.uk/showproduct.php?prodid=MO-043-AS&groupid=17&catid=1120&subcat=
So i ask for you help plz on weather to go for a 120HZ or even a 144HZ or go for the other one, or even if you know another good one plz help.. ive been reading too much stuff and confused, i even considered an ips one but there well expensive.
I just want gr8 viewing and no ghosting while playing..
Any input would be greatlly appreceated..
Many thx
K.............................
heheNow i was alwasy under the impression that the lower the response time the better thats why i was thinking of getting a 120hz one like this one but reckon ill not use 3d that much:- http://www.overclockers.co.uk/showproduct.php?prodid=MO-033-AS&groupid=17&catid=1120&subcat=
Many thx
