New monitor
27 Oct 2008
Gloucester
I've currently got two Dell 2309 monitors running at 2048x1152 each. I'm looking at getting a bigger monitor but I can't bring myself to buy a 4k as I don't think my GPU (a 7990) can cope with it.
So, what's the best 1440 I can get for around the £500 mark?
If your budget can stretch to it, the Asus ROG Swift N-Sync is on offer this week... great choice if you're into gaming. :)
I would only go for the rog if you intend on getting an nvidia GPU at some point.
Also, need to know what your usage is, requirements i.e. better colours, viewing angles or fast response time, high refresh rate etc.? :)
I'm using the Asus 1440p PLS monitor and cannor fault it. Ivr Overclocked the refresh rate to 80hz which makes gamung slightly smoother.
So you just game or do you require accurate colour reproduction?
I'm only really after a bit more screen real estate. I'm happy with the two monitors I've got but they're getting on a bit now. Just fancy a change.
Just ordered it but the web site was proper sluggish so took a few attempts.
I've only gone and ordered it to be sent to my old address :(
