Current monitor has started to break, have about 24 different coloured vertical lines on the far right side of the screen (yellow/purple/cyan/blue).
Budget wise looking at £200-350+, main use gaming. Cpu is a 3600 and gpu is a 970, do need to upgrade the gpu. Is it worth sticking with 1080p or move to 1440p?
I have been looking at a few monitors, Aoc 24G2U/27G2U both ips and 144hz. Did consider the LG 27GL850-B, though the price has gone from £350-400 to £500. Their was a different version to the 850, LG 27GL83A, though no stock on that monitor in the UK.
Are their any different monitors that i need to consider, though stock is low everywhere.
