I prefer the FI27Q when it comes to image quality, it has a smooth panel coating, mine had 1300:1 contrast ratio compared to the 750:1 of the LG panels. The FI27Q is actually an Innolux panel which use a form of In-Plane you get better viewing angles than AHVA In-Plane panels which AUO use.
If you're strictly a competitive gamer, the LG panel would be a better option. For all around use if you want better image quality, consider a good VA panel like the AG273QX.
