New monitor
18 Jan 2015
Consett
Hello guys,
I've been looking to get a new monitor to go with my 3080Fe.
I really wanted to get the MSI that everyone recommended a few weeks ago but it's now insanely overpriced at other retailers and ocUK is oos.
Is there another good alternative to it?
I have seen someone recommend this
https://www.overclockers.co.uk/lg-2...le-widescreen-led-gaming-monit-mo-155-lg.html
Is this the best alternative?
My max budget is £300
Thanks.
Yeah i think it's pretty much the best your currently going to get for the price i had a look around and the only other option i would consider is the Dell S2721DGF but it's slightly over you budget at £329 but then you do get and extra 1 year warranty and better 1 pixel panel return policy.
In response times also LG's Nano-IPS panel is at top level.
Unfortunately contrast is again from 15 years ago and far below IPS normal.
So black level is crappy and you'll need normal room illumination for dark shades to not look grey.
That Dell uses also same LG panel.
