New Monitor
20 Feb 2011
Hi,
I am looking for either a new dual monitor setup or one ultrawide monitor that works best with an AMD 6800XT GPU. Main purpose is gaming (Warzone etc). With ultrawide monitors can you select a display size say 27inch to play on and leave the rest of the screen for something else?
Thanks in advance
You know I had never considered that.
Some of the newer Alienware monitors have PIP. I honestly don't know if they can do what you suggest, but I would certainly check it out.
Personally, I would use dual monitors. It's just easier. Any old monitor will do for the secondary.
