New Motherboard, now "no signal" on monitor? HELP
4 Aug 2005
Hi guys i'm in the middle of a upgrade from a asus a8n sli-deluxe to a DFI sli-dr, i re-formatted the hard drive prior to the change over, i hooked everything up correct, my computer will power on, and everything is spinning up but for some reason my monitor reports no reply? i have tried disconnecting everything except the monitor, clearing cmos, changeing ram ports.
Help someone as this is really starting to do my head in? :D
yeah i had, solved the problem now, although it has caused another minor one :(, it was just that on my old asus board the top most pci-e slot was slot 1 and apparently on the dfi it's slot2? so i put it in the lower pci-e slot and worked first time DOH, how ever as my old modded 6600 card is taking up two slots with it's vantec cooler i now only have 1 pci slot and i have a wireless card and fatal1ty fps card to put somewhere :'( looks asthough a new gfx card is on my horizons although it has to be a single slot, something like a 7800gtx me thinks
