NEW MSI OVERCLOCKED BUNDLES AND SYSTEM!
11 Dec 2005
Cheshire
"Titan Supersaurus" Intel Core i5 2500K 3.30GHz @ 4.50GHz DDR3 Sandybridge System @ £923.39 inc VAT
The Supersaurus was the largest Herbivore to roam the World in times once gone by, now embrace the power of the legendary dinosaur with the "Titan Supersaurus". Featuring the Intel Core i7 2500K overclocked to a storming 4.50GHz and can be equipped with the most powerfull graphics cards available, the "Titan Supersaurus" is literally armed to the teeth. For the extreme among you, you can upgrade to a GTX 580 enabling you to dominate all the opposition. Contained within the sleek Coolermaster CM 690 II Dominator case finished in stunning black.
Why You Should Buy This System
- A guaranteed 4.50GHz performance for the price of 3.30GHz
- DX11 cinematic graphics for the ultimate performance
- Precision built and cabled by Overclockers UK expert technicians
- SATA 6GB/s, Intel Ethernet for next gen computing
System Specification
- Case: Coolermaster CM 690 II Dominator Advanced - Black
- Power Supply: XFX Pro Core edition 650W PSU
- CPU: Intel Core i5 2500K 3.30GHz Overclocked to 4.50GHz Sandybridge CPU
- Motherboard: Intel P67 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: Corsair H60 CPU Cooler
- RAM: 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: Samsung 1TB F3 + Crucial M4 64GB Sata 6GB/s Solid State Drive
- Graphics Card: MSI 560TI base option (upgrade options available)
- Sound: Asus Xonar DG PCI Sound Card
- Optical Drive: DVD+/-RW SATA Drive
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Embrace the power of the "Titan Supersaurus" with DX11 graphics and Intel Sandybridge technology. Take the advantage with the "Titan Supersaurus".
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Only £929.39 inc VAT.
ORDER NOW
"Radon Utahraptor" Intel Core i5 2500K 3.30Ghz @ 4.40Ghz Overclocked Bundle - MSI @ £359.98 inc VAT
Designed by experts the "Radon Utahraptor Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed unseen at this price point ever before. The "Radon Utahraptor Bundle" will accelerate your computer experience into the next level.
Why You Should Buy This Bundle?
- A solid, optimised 4.40GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- USB3, SATA 6GB/s, Intel Ethernet and EUFI graphical BIOS for next gen computing
Bundle Specification
- CPU: Intel Core i5 2500K 3.30GHz @ 4.40GHz Sandybridge CPU
- Motherboard: MSI P67A-G45 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- RAM: Kingston HyperX Blue 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Cooler Master Hiper 212 Plus
- Artic Silver 5 Thermal Compound
Service Package
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Only £359.98 inc VAT.
ORDER NOW
"Radon Apatosaurus" Intel Core i5 2500K 3.30Ghz @ 4.50Ghz Overclocked Bundle - MSI @ £348.00 inc VAT
Designed by experts the "Radon Apatosaurus Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.50GHz overclock has the processing power and speed unseen at this price point ever before. The "Radon Apatosaurus Bundle" will accelerate your computer experience into the next level.
- A solid, optimised 4.50GHz overclock profile provides outstanding processing performance
- CPU: Intel Core i5 2500K 3.30GHz @ 4.50GHz Sandybridge CPU
- Motherboard: MSI P67A-GD53 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
Service Package
Only £348.00 inc VAT.
ORDER NOW
"Krypton Baronyx" Intel Core i7 2600K 3.40Ghz @ 4.60Ghz Overclocked Bundle - MSI @ £589.99 inc VAT
Designed by experts the "Krypton Baronyx Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.60GHz overclock has the processing power and speed unseen at this price point ever before. The "Krypton Baronyx Bundle" will accelerate your computer experience into the next level.
- A solid, optimised 4.60GHz overclock profile provides outstanding processing performance
- 8GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- CPU: Intel Core i7 2600K 3.40GHz @ 4.60GHz Sandybridge CPU
- Motherboard: MSI Z68A-GD80 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- RAM: Kingston HyperX Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Cooler Master V6GT
Service Package
Only £589.99 inc VAT.
ORDER NOW
"The Supersaurus was the largest Herbivore to roam the World in times once gone by, now embrace the power of the legendary dinosaur with the "Titan Supersaurus". Featuring the Intel Core i7 2500K overclocked to a storming 4.50GHz and can be equipped with the most powerfull graphics cards available, the "Titan Supersaurus" is literally armed to the teeth. For the extreme among you, you can upgrade to a GTX 580 enabling you to dominate all the opposition. Contained within the sleek Coolermaster CM 690 II Dominator case finished in stunning black."
