Hi Guys
You have asked, and we have delivered. Due to overwhelming demand in the product suggestion forum, we now have listed a superb range of Netgear, high end switches along with other products from the Netgear range.
Netgear Wireless-N Universal Range Extender WN2000RPT @ £49.99 inc VAT
The NETGEAR Universal WiFi Range Extender allows you to keep your current wireless equipment and improve wireless coverage to eliminate dead zones. It is compatible with wireless b/g/n routers, gateways and Internet service provider devices. It allows freedom to roam anywhere in the house and access Internet without worrying about coverage. A bonus feature is 4 Ethernet ports to connect to gaming consoles, Internet TV’s, and Blu-ray players. A real-time link-rate LED locates the best placement spot to provide optimal wireless coverage and a graphical guide makes installation easy. There’s no need to insert a CD or plug in Ethernet cables!
• Keep your current wireless equipment and improve coverage to eliminate ‘dead zones’
• Compatible with wireless b/g/n routers, gateways and Internet Service Provider‘s devices
• Freedom to roam anywhere in the house and access Internet without worrying about coverage
• Bonus feature—4 Ethernet ports to connect to gaming consoles, Internet TV’s, and Blu-ray players
• Works with any wireless b/g/n router or gateway from NETGEAR and other brands
• Works with all security standards including WPA-PSK, WPA2-PSK, mixed mode and WEP
• Real-time link-rate LED locates the best placement spot to provide optimal wireless coverage
• Step-by-step, graphical Installation Guide makes installation easy. No need to insert a CD or plug in Ethernet cables!
• Dynamic LEDs display live network connection status and signal strength between your existing network, Extender and computers (or other Internet-connected devices)
• Push ‘N’ Connect using Wi-Fi Protected Setup™ (WPS) connects computers to the Extender quickly and securely1
• Four (4) Ethernet ports allow the Extender to function as a wireless bridge to connect to home AV devices
Only £49.99 inc VAT.
ORDER NOW
Netgear ProSafe FS105 5-port 10/100 Compact Switch @ £19.99 inc VAT
NETGEAR's cost effective FS105 Fast Ethernet Switch provides your network with high-speed, 10/100 Mbps auto-sensing connectivity. This 5-port switch is incredibly easy to set-up, just plug in your Ethernet networking cables and connect a power cord. Engineered without the need for internal fans, the FS105 operates silently.
Compact
Solidly built in small sizes that are easy to position when space is at a premium.
Simple to Use
Once you connect the hardware, your switch is operating!
Quiet
No fan means no noise, which helps maintain a peaceful atmosphere in your busy office.
Great Value
Competitively priced—compare them to others and see the difference.
Product Highlights
• All 5 ports switch automatically senses the right networking speed: 10 or 100 Mbps
• Engineered without the need for internal fans, the FS105 operates silently
• No software to configure, the FS105 switch operates as soon as you connect it
• Housed in a compact, sturdy metal case for years of dependable use
Number of Built-in Ports
• 5 x 10/100Mbps port
• Auto-Uplink
• Auto-Sensing
• Fall/Half Duplex
Network latency
• Less than 20 microseconds for 64-byte frames for 100 Mbps to 100 Mbps transmission
Dimensions
• 158 x 103 x 27 mm (WxDxH)
• (6.2" x 4.1" x 1.1 inches)
Manufactures Warranty
• 5 years for unit
• 1 year for power adapter
Package Contents
• NETGEAR FS105 Fast Ethernet Switch
• Wall-mount kit
• AC adapter
• Quick Installation Guide
• Warranty and registration card
Only £19.99 inc VAT.
ORDER NOW
Netgear ProSafe GS724T Gigabit Smart Switch @ £139.99 inc VAT
Joining NETGEAR's family of Smart Switches with simple switch management at no extra cost, this 24-port Gigabit switch is high on value and capability. With 24 10/100/1000 Mbps ports, each capable of powering 2000 Mbps of data throughput in fullduplex mode per port, plus two optional fiber ports, it provides fast backbone and connects servers or power users, delivering large amounts of multimedia, image, and video information in no time at all.
In addition, an intuitive, Web-browser interface offers the simple Smart Switch management, making it a snap to monitor switch performance, configure ports, even set up port trunks, VLANs, and traffic prioritization. Alternatively, use SNMP-based software to manage your Smart Switch. Shipped ready for use straight out of the box, it delivers switching that's easy to set up and use. NETGEAR ProSafe Smart Switches are ideal for adding basic management to your unmanaged networks and extending your managed networks.
Intelligent
Smart Switch capability enables key management features for the value price of an unmanaged switch. Included are performance monitoring, port configuration, VLAN for traffic control, port trunking for increased bandwidth, and Class of Service (CoS) for traffic prioritization.
Enhanced Security
These Gigabit Smart Switches provide advanced features that provide more robust security to the SMBs. These include:
• 802.1x for authentication
• ACL filtering to permit or deny traffic based on MAC or IP addresses.
Advanced Quality of Service (QoS)
Priority queuing ensures high-priority traffic gets delivered efficiently, even during congestion from high-traffic bursts. Companies implementing network telephony or video conferencing, for example, need to be able to prioritize such voice and video traffic and other real-time applications over less latency-sensitive traffic to ensure reliability and quality. The ability to prioritize traffic ensures quality of latency-sensitive services and applications despite increasing traffic loads. The ProSafe Gigabit Smart Switch provides an extensive set of QoS features:
• 802.1p-based prioritization
• Layer 3-based prioritization
• Rate-limiting
Only £139.99 inc VAT.
ORDER NOW
Netgear RangeMax Next Wireless-N PCI Adapter WN311B @ £32.99 inc VAT
This RangeMax NEXT PCI adapter ensures that your desktop computer can connect from anywhere in your home, with maximum coverage and bandwidth, enabling you and the rest of your household to simultaneously connect to multiple Internet services, including online gaming, video streaming, and MP3 downloads.
When used in conjunction with NETGEAR's WNR834B RangeMax NEXT wireless cable router, the WN311B PCI adapter will provide maximum coverage and bandwidth, enabling you and your entire household to simultaneously connect to multiple Internet services and online media.
To explain the capabilities of RangeMax NEXT wireless router and adapters further: Imagine connecting to the Internet from anywhere in the house, without a cable. Then imagine everyone in the house connecting at the same time, and all doing things online or over the network - all at the same time: Watching a Hi-Definition video or TV program in the living room, browsing the Internet in the study, playing online games in the den, downloading MP3 music from the dining room - all at the same time. This is what RangeMax NEXT is capable of, all over a single home wireless network that provides a constant, 'rock-steady' connection.
With the RangeMax NEXT PCI desktop PC adapter inserted, your computer will maintain a steady, constant connection (when used in conjunction with the WNR834B Wireless Router), with sufficient bandwidth available to stream, download, browse the Internet, and transfer files all at the same time.
With RangeMax NEXT you should not experience any more frustrating interruptions or freezes, just a constant connection that enables you and your household to use the Internet and wireless network as you choose, whenever you choose.
Touchless WiFi Security makes creating the highest level of network security easy and includes industry standard wireless encryption standards for you to choose from: WEP, WPA-PSK, or WPA2-PSK. These security features enable you to 'lock-down' your home wireless network, protecting you against unwanted intruders.
As with all NETGEAR wireless products, the WN311B RangeMax NEXT wireless PCI adapter is easy to set-up with NETGEAR's Smart Wizard. This RangeMax NEXT adapter is backward compatible with existing wireless devices, including 54 Mbps 802.11g and 11 Mbps 802.11b - but bear in mind that the coverage and bandwidth won't be as good with these devices on your home wireless network.
Only £32.99 inc VAT.
ORDER NOW
Netgear ProSafe FS108 8-port 10/100 Compact Switch @ £21.98 inc VAT
NETGEAR’s popular FS100 series desktop switches, known for its reliability and performance, provide your LAN with high-speed, 10/100 Mbps auto-sensing connectivity for as many as 5, 8, or 16 users. Just plug in your Ethernet cables, connect a power cord, and you’re ready to go-there’s no software to configure. They negotiate to the fastest possible connection and with Auto Uplink™ technology, these switches automatically figure out if the link needs a straightthrough or cross-over connection, and makes the right choice. Existing 10BASE-T devices are easily integrated within higher bandwidth environments, with full wire speeds on all ports of either 10 Mbps or 100 Mbps. Engineered without the need for internal fans, they operate
silently. And each of these very compact switches is housed in a sturdy metal case for years of dependable use.
At Your Service
Five, eight, or sixteen ports provide LAN access for many users. Every port supports up to 200 Mbps in dedicated bandwidth and traffic is forwarded flawlessly with automatic flow control.
Compact
Solidly built in small sizes that are easy to position when space is at a premium. Ideal for conference rooms, class rooms, study groups or small offices. Place it on any flat surface or use the included wall mount kit to tuck it out of the way.
Simple To Use
Once you connect the hardware, your switch is operating! Auto negotiation takes care of the speed and duplex, while Auto Uplink takes care of the MDI/MDI-X connection. Eliminate the need for toggle switches or special crossover cables.
Quiet No fan means no noise, which helps maintain a peaceful atmosphere in your busy office.
Only £21.98 inc VAT.
ORDER NOW
Netgear FS605 5-port 10/100 Switch @ £13.99 inc VAT
Netgear FS605 5 Port 10/100 Desktop Switch
Hang on – your network will soar when it’s hooked up to NETGEAR’s FS605! This powerful plug-and-play switch connects at 10 or 100 Mbps and makes it easy to link as many as five computers or peripherals to your Ethernet network. You’ll experience maximum performance for 10 or 100 Mbps devices with five ports that automatically sense the correct speed while Auto Uplink™ on the ports adjusts for the different types of Ethernet cables. The FS605’s sleek case has lights on the front for easy monitoring. Installation into your home network couldn’t be simpler and, once powered on, it begins cool and silent operation – without an internal fan.
Versatile
Connects up to five computers, servers, printers, switches or any other Ethernet devices at 10 or 100 Mbps over Ethernet cables. Works with virtually any operating system (Microsoft® Windows®, Apple® Macintosh®, Linux® and more).
User-Friendly
Designed specifically for home and small office users with Plug-and-Play installation, rear ports that reduce cable clutter, and front status lights for easy monitoring.
Resourceful
All five ports deliver automatic speed and duplex sensing, plus Auto Uplink adjusts for different Ethernet cable types to make the right link everytime. No connection problems from using the wrong cable.
Well-Designed
Sleek, modern case combines with other NETGEAR Platinum products so you can place them on top of each other. Or you can use the included vertical stand to conserve desk space. Trust your network to NETGEAR’s built-to-last reliability from using high-quality components.
Key Applications
• Multiple applications running simultaneously—downloads, voice, music, VoIP
• Multiplayer gaming over the home network
• Multimedia/video streaming within the home
• Networked or shared storage/large file sharing
Only £13.99 inc VAT.
ORDER NOW
Netgear DG834 ADSL Modem Router @ £44.95 inc VAT
Add mobility to your home network, by upgrading to the wireless enabled version.
All-in-one Gateway for Always-on Broadband Access with Internet Sharing
Four products in one, The NETGEAR DG834 is a multitalented firewall router combining an ADSL modem, router, four-port 10/100 LAN switch, and SPI Double Firewall to deliver broadband access that’s continuously available for sharing with all your networked devices.
Simple to use, the NETGEAR DG834 plugs directly into your ADSL line for instant connectivity to network resources and the Internet, and an integrated switch lets you directly connect up to four computers or any combination of four computers, access points or printers.
Setup couldn’t be easier with NETGEAR’s unique Smart Wizard install assistant helps to guide you each step of the way. The Smart Wizard also automatically detects and makes the optimal connection to your ISP. The NETGEAR DG834 contemporary, sleek design suits your home or office, and it’s wall mountable to save valuable desk space. Upgradeable with new enhancements via the Internet.
Ultra-capable
One router supplies your network with impressive capabilities. A built-in ADSL modem furnishes direct, always-on Internet connectivity and multi-user access sharing at speeds up to 140 times faster than dial-up. The NETGEAR DG834 distributes MP3s, digital movies and photos with ultra-fast 10/100 switched LAN ports capable of speeds of 200 Mbps and and shares a single IP address with all the networked devices in your home. Upgradeable to ADSL 2+ for speeds up to 24 Mbps.
Hassle Free
No need for a separate modem – NETGEAR DG834 connects directly into your ADSL line. Built-in Port Forwarding settings, Universal Plug and Play (UPnP) make it simple to play Internet games, send instant messages, and host Internet services. User interface matches your local language (English, French, German or Italian). It supports PCs, Macintosh®, and virtually all Ethernet devices, and comes with a free Ethernet cable for connecting your first computer.
Secure
The NETGEAR DG834 Double Firewall using Stateful Packet Inspection (SPI) and Intrusion Control features Denial of Service protection from hacker attacks, while VPN (Virtual Private Network) pass-through permits secure access to your office or corporate network and enables you to host VPN services. Content filtering lets you control access to inappropriate web sites and limit usage by time of day. Logs browsing activities and provides optional e-mail alerts so you can monitor access. DMZ support allows unrestricted access from the Internet to one computer (for hosting web services).
Only £44.95 inc VAT.
ORDER NOW
Netgear ProSafe GS116 16-port Gigabit Switch @ £94.99 inc VAT
Power Up Your Small Network to Gigabit Speeds
Now you can have a powerful, high-speed network on a small scale. NETGEAR's GS116 Gigabit Ethernet Switch lets you build a system that provides a full, dedicated 1000 Mbps connections so you can move very large files across your network instantly. The standards based NEGEAR GS116 helps to protect your existing and future network infrastructure investments by painlessly integrating other 10, 100, and 1000 Mbps devices. This potent switch is ideal for workgroups or quickly upgrading workstations to full Gigabit speed, plus it's packed with ease-of-use features to simplify your workday experience. It's compact design fits neatly into small work spaces and, since it's self-cooling without a fan, it runs silently and unobtrusively.
Power Packed
Moves huge files fast! Features 16 high-speed, auto-switching 10/100/1000 Mbps Ethernet connections. And because Copper Gigabit Ethernet is a full duplex standard, you can get up to 2000 Mbps on each port.
Versatile
Integrates 10, 100, and 1000 Mbps devices on the same network and will honor Layer 2 802.1p traffic priority tags. Every port automatically senses the right speed and full/half duplex mode, while Auto UplinkTM technology automatically adjusts for straight-through or crossover cables.
Accommodating
LEDs embedded in each of the 16 RJ-45 jacks make for easy monitoring. Space-saving dimensions are ideal for desktop or wall mounting in home, small office, workgroups, departments and conference room environments. Its durable metal case has no fan for silent operation. Compatible with either PC, Macintosh, Unix, or Linux operating systems.
Solid
Providing plug-&-play simplicity with exceptional performance and reliability, the NETGEAR GS116 is a cost effective solution for your growing network. This switch is made to last and NETGEAR backs it with a solid warranty: switch - 5 years, power supply - 2 years.
• Each port delivers up to 2000 Mbps of network speed (full duplex)
• Fast, auto-switching and auto-sensing 10/100/1000 Mbps Ethernet connection
• 16 switched ports provide bandwidth for PCs, servers or switches
• Auto Uplink™ automatically adjusts for straight-through or crossover cables
• Supports jumbo frames up to 16 KB
• Honors TOS/802.1p prioritization
Only £94.99 inc VAT.
ORDER NOW
ORDER NOW
Compact
Simple to Use
Quiet
Great Value
Product Highlights
• Auto-Uplink
• Auto-Sensing
• Fall/Half Duplex
Network latency
Dimensions
• 5 years for unit
Package Contents
• Wall-mount kit
• AC adapter
ORDER NOW
Intelligent
Enhanced Security
• Rate-limiting
ORDER NOW
ORDER NOW
At Your Service
Compact
Simple To Use
ORDER NOW
Versatile
User-Friendly
Resourceful
Well-Designed
Key Applications
ORDER NOW
Ultra-capable
Hassle Free
Secure
ORDER NOW
Power Packed
Versatile
Accommodating
Solid
ORDER NOW
