- 14 Apr 2008
- Manchester
Hi All,
My company is moving offices and we're taking the opportunity to implement our network properly, now, since i've been put in charge of it and since my real job is as a software developer, i was looking for some advice on my proposed design.
Now, in an ideal world i'd just use all Cisco kit and be done with it, but because of budgetary constraints and us already owning some kit it's not really practical.
The diagram outlines my current design
The L2 switching consists of:
Current:
2x 16 Gigabit 'LevelOne' branded (these were bought without my knowledge so we're stuck with them)
Cisco 2900XL 24-Port
Proposed
1x Linksys SRW248G4P 48-Port PoE
1x Linksys SLM248G 48-Port
We have a requirement for around 10 IPSEC VPNs and 10 VLANS as well as inter-VLAN routing and statefull firewalling.
When i called one of our suppliers to see what they suggested it became apparent i wasn't going to be able to get away with a Cisco 877 and our current L2 switching. The guy suggested a L3 switch which solves the inter-VLAN routing issue but even though we'd have ACLs there isn't any stateful firewalling.
This has led to the proposed solution to used a PC based software router - ok so the performance isn't going to be as good but we don't have a requirement for high performance inter-vlan routing.
What would you do in this situation? Our current Modem/Router is a Draytek 2800, though we've got a 2820 in the office spare already which could be put to use.
![netdia1.jpg](http://www.lewty.org.uk/netdia1.jpg)
Current:
Proposed
