Guys,
Hope you can help me. This is my first home build in a few years and i'm clearly not as l3370r as I thought I was back then, cos I'm having no joy here.
Just purchased from OCUK:
Akasa Eclipse 62 Aluminium Case
Asus Striker II Formula nForce 780i (Socket 775) PCI-Express DDR2 Motherboard
Leadtek GeForce 8800 GTX 768MB GDDR3 HDTV/Dual DVI (PCI-Express)
2 of Crucial Ballistix 2GB (2x1GB) DDR2 PC2-8500C5 1066MHz Dual Channel Kit (so 2 pairs of 2)
Tuniq Tower 120 CPU Cooler (Socket 478/754/939/940/AM2/LGA775)
OCZ ModXStream 900w Silent SLI Ready ATX2 Power Supply
Plus samsung F1 drive and a DVDRW etc blah.
All of it completely stock no tweaking. Just thin application of arctic silver betwen the tuniq and an E8500 (wolfdale 3.16GHz). No timing adjustments or freqs etc.
Problem 1: That mobo is one HOT mofo. 80C on the NB just booting into an OS. NB HS is hot too so there is a proper(ish) connection. These boards are supposed to be for people who want to overclock - 80C stock? No way.
Problem 2: It won't take both RAM kits, no matter what I do. If it gets past POST it crashes during OS boot. Both kits work fine independently, it's only if they're in there together. (I preserve their shipped pairing of course, I haven't mixed them up.)
Problem 3: The RAM should work just fine at 1066. No, can't get more than 800 out of it otherwise no POST.
Problem 4: The RAM wants 2.2v I think - BIOS is giving it 1.88 by defaults and won't be persuaded otherwise (or it's no POST for me)
All in all very disappointing. It's hot, it won't drive a perfectly good set of RAM all on defaults, doesn't look like it will ever overclock without melting through my table (although that's secondary really), and I'm wondering if I have either been shipped a badly built one, or they're just not great anyway.
Any advice very much appreciated as i'd like to get back into homebuilding, modding, and clocking. If not, it's back to Dells for me (and nobody wants that now do they?) I've got until Saturday if I want to reject the board as utterly useless under distance selling regs.
Oh, and yes, I'm aware the board might not be at fault, it just looks very likely to me atm. Could be PSU I guess but i'm finding that unlikely.
Many thanks,
Raf
Many thanks,
Raf
