** NEW OcUK Pre-Watercooled Case Range **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Just in time for the weekend, OcUK are proud to announce the availability of a full case range with pre-installed watercooling kits.
These kits are assembled in house and ready for you to build your dream PC inside.
As with all OcUK watercooling products, the sheer variety of kit on offer means that we are always open to suggestion. If you require a certain case/coolant/tubing layout. Then please call our sales team who will be happy to amend or customise your pre-watercooled case to your requirements [dependant on compatibility].
V6 Single Radiator Cases
OcUK V6 Watercooled Case - BitFenix Shinobi @ £199.99 inc VAT
Assembled by Expert OcUK Technical Staff, the V6 range of Pre-Watercooled cases brings you exceptional performance paired with incredible value for money!
The OcUK Watercooled Case range comes pre-assembled for your convenience. All of the difficulty of watercooling has been removed and allows you to enjoy the best performance without the hassle.
All of our pre-watercooled cases are built to order and come pre filled ready for you to build your dream system.
The system is shipped with Clear Mayhems Ultra Pure Fluid. If you prefer us to use a coloured fluid, please call our sales team to enquire about coloured coolant.
PLEASE CHOOSE THE CORRECT MOUNTING BRACKET FOR YOUR CPU
BitFenix Shinobi Gaming Windowed Case - Black
- Dimensions: 205 x 460 x 490mm
- Motherboard Sizes: Mini-ITX, mATX, ATX
- 5.25" Drive Bays x 3
- 3.5" Drive Bays x 8
- 2.5" Drive Bays x 2
- Front Cooling: 2 x 120mm Fans (optional) 1 x 120mm Fan (included)
- Rear Cooling: 1 x 120mm Fan (included) or 1 x 92mm Fan (optional)
- Top Cooling: 2 x 140mm Fans (optional) or 2 x 120mm Fans (optional)
- Bottom Cooling: 1 x 120mm Fan (optional)
- Expansions Slots: 7
- I/O Ports: 4 x USB2.0 & 1 x Audio
"EK-KIT H3O - Supreme LT 120" water cooling kit includes following items:
- EK-Supreme LT - UNI (universal CPU block based on EK-Supreme LT)
- EK-Backplate CPU Universal
- EK-CoolStream RAD XT (120)
- Yate Loon D12SH (2200rpm) or Yate Loon D12SM (1650rpm)
- EK-DCP 2.2 Pump
- EK-Reservoir Combo DCP 2.2
- EK-DCP PUMP mounting plate KIT
- TUBE Masterkleer 12,7/9,5 CLEAR (2 meters)
- EK-PSC Fitting 10mm - G1/4 Nickel (6 pcs)
- EK-Ekoolant UV Blue (concentrate 100ml)
- TIM Arctic Cooling MX-2 (EKWB 2g)
Only £199.99 inc VAT.
ORDER NOW
OcUK V6 Watercooled Case - Zalman Z9 @ £184.99 inc VAT
Zalman Z9 Plus Tower Case with Fan Controller - Black
- Motherboard tray cut out for easy CPU backplate removal
- Dimensions: 207 x 464 x 504mm (W x H x D)
- 3 x 5.25" Drive Bays
- 6 x 3.5" Drive Bays
- 1 x 2.5" Drive Bay
- Expansion Slots: 7
- Space for 290mm Graphics Cards
- Front I/O Ports: USB2.0 x 4 / 2 x Audio / Fan Controller / Temperature display
- Front Cooling: 120mm /140mm fan x 1 (120mm Blue LED fan x 1 standard)
- Top Cooling: 120mm /140mm fan x 2 (120mm Blue LED fan x 1 standard)
- Bottom Cooling: 120mm /140mm fan x 1 (optional)
- Rear Cooling: 120mm fan x 1 (included)
- Side Cooling: 120mm fan x 2 (120mm Blue LED fan x 1 included)
- EK-DCP 2.2 Pump
Only £184.99 inc VAT.
ORDER NOW
V8 Double Radiator Cases
OcUK V8 Watercooled Case - Corsair 650D @ £289.99 inc VAT
Corsair Obsidian 650D Gaming Midi Tower - Black
- Motherboard Support: ATX / mATX
- Expansion Slots: 8
- Drive Bays: 5.25" x 4 & 3.5"/2.5" x 6
- Cooling: 2 x 200mm Fans and 1 x 120mm Fans
- Front I/O Ports: USB2.0 x 4 / FireWire x 1 / Audio x 2 / 4-Channel Fan Controller
- Dual 200mm fans provide outstanding cooling for even the hottest components
- Easily accessible dust filters make maintenance simple and hassle-free
- Quick-release side panels make it easier than ever to upgrade your hardware
- Integrated fan controller lets you quickly adjust cooling performance and noise levels
- Four tool-free optical drive bays and up to six SSD-ready hard drive trays provide plenty of expansion
- CPU backplate cutout makes it easy to upgrade your CPU cooler
- Brilliant cable routing system provides a way to keep your system neat and tidy
- Adjustable drive cages can be removed and relocated to accommodate large video cards
- Room for long power supplies gives you peace of mind for future upgrades
- Dimensions: 546mm (L) x 229mm (W) x 521mm (H)
EK-KIT H3O - Supreme LT 240 water cooling kit includes following items:
- EK-CoolStream RAD XT (240)
- EK-DCP 2.2 Pump
Was [OLDPRICE] Inc. VAT
Only £289.99 inc VAT.
ORDER NOW
OcUK V8 Watercooled Case - Cooler Master CM-690 Lite Dominator @ £229.99 inc VAT
Cooler Master CM-690 II Lite Dominator Case - Black
- Dimensions: 214 x 511 x 528mm
- Motherboard Compatiblity: ATX, Micro-ATX, Mini-ITX
- Room for 120 x 240mm Radiator inside the top and bottom
- Cable management and CPU retaining holes for easy maintainence
- Support Tri-GFXs
- 4 x 5.25" Drive Bays
- 7 x 3.5" Drive Bays
- I/O Panel: USB2.0, 1 x eSATA, 2 x Audio
- Front Cooling: 1x 120 mm (17 dBA)
- Rear Cooling: 1x 120 mm (17 dBA)
- Top Cooling: 2 x 140 / 120 mm (optional)
- Bottom Cooling: 2 x 120 mm (optional)
- HDD Cage cooling: 1x 120 mm (optional)
- EK-DCP 2.2 Pump
Only £229.99 inc VAT.
ORDER NOW
V12 Triple Radiator Cases
OcUK V12 Watercooled Case - Corsair 800D @ £399.98 inc VAT
Corsair Obsidian 800D (6GB/s) Full Tower Case - Black
- Four easily accessed hot-swap drive bays
- Removable CPU backplate panel for easy heatsink installation
- Isolated cooling zones prevent heat buildup
- Unique cable routing holes guarantee a clean and clutter-free installation
- Three fans included, with the ability to add four more 120mm fans
- Tool-free optical drive installation makes building a system faster than ever
- Two year warranty with Corsair’s world-class customer service and technical support
- Dimension: 609mm X 609mm X 229 mm
- 5 x 5.25" Drive Bays
- 4 x 3.5" SATA Hot Swappable Bays
- 2 x 3.5" Internal Bays
- Cooling: 3 x 140mm fans (included)
- Cooling: 4 x 120mm fans (optional)
- Front I/O: 4x USB 2.0, 1x FireWire, 2x Audio
EK-KIT H3O - Supreme LT 360 water cooling kit includes following items:
- EK-CoolStream RAD XT (360)
- EK-DCP 2.2 Pump
Only £399.98 inc VAT.
ORDER NOW
OcUK V12 Watercooled Case - Coolermaster HAF X @ £309.98 inc VAT
The much anticipated HAF X arrives as the flagship of the popular HAF (High Air Flow) series. Designed for performance systems, this chassis is able to house today's latest and hottest CPUs, motherboards, GFX cards and is even USB3.0 compatible. With specialised support and cooling for graphic cards, massive airflow with the help of up to four gigantic fans and easy access to installed components, this is as close as it gets to a system builder's 'dream case'.
- Dimensions: 230 x 550 x 590mm ( W x H x D)
- Motherboard Compability: Micro- ATX, ATX and E-ATX
- 6 x 5.25" Drive Bays
- 5 x 3.5" Drive Bays
- I/O Panel: USB3.0 x 2, USB2.0, Audio x 2, e-SATA x 1, FireWire x1
- Cooling (Front): 230 x 30 mm red LED fan x1
- Cooling (Top): 200 x 30mm fans x 2 (1 included)
- Cooling (Side): 200 x 30mm fan x 1
- Cooling (Rear): 140 x 25mm fan x 1
- VGA Fan Duct: 120 x 25mm fan x 1 (not included)
- VGA Holder: 80 x 15mm fan x 1 (not included)
- PCI Slots: 9
- Bottom mounted PSU
- EK-DCP 2.2 Pump
Only £309.98 inc VAT.
ORDER NOW
I'm slightly confused...how do you put your computer inside if you got the loop already in there? :confused:
Nice choice of kit there, good for the enthusiast who doesn't want to spend lots of time picking kit. (although it's one of the best parts of WC'ing, picking your own kit)
for the 12th time this evening :p
the case comes pre fitted with the kit.
you put the cpu block mounting kit on your motherboard and install it into the case.
you then build the rest of your pc as normal.
you mount the cpu block like you would with any heatsink [although mounting a cpu block is a piece of cake compared to mounting other coolers]
then you are ready to go.
the watercooling is preconfigured and filled/leaktested ready to go.
there are full intruction manuals too
the beauty of it is that even with the kits, i noticed that a lot of people were still hesitant to invest but like the idea of a watercooled system.
this way, anyone who can build a computer can have a full custom watercooling loop without having to worry about the fear of putting it all together.
Oooooh. :p
Sounds good! Is OcUK planning to take on the dedicated WC shops in the UK with the new range, or is it just a supplementary thing?
What a brilliant idea :) Takes the worry out of the conception especially for someone like me, knows nothing of WC and has a small baby so limited time, i do have fish tanks though :D
I just wish i'd seen this a month ago, still interested in the WC kits.
Oooooh. :p
the WC shops in the UK are good, they have a lot of different lines. we are not trying to take anyone on, our own range will speak for itself.
OcUK are concentrating only on good quality watercooling products.
we are not going to stock every last thing on the market, but what we do stock is only going to be the stuff that is worth buying.
Its all well and good listing thousands of different fittings etc, but if nobody wants to buy an item then it is a bit of a waste.
get one of the kits instead if you have a case that accommodates one :)
correct - we have a full range of Mayhems due to land soon.
Mayhems is all made to order and our initial order is currently in production.
as soon as its here there will be a news post and announcements made.
OcUK will only be stocking quality watercooling components.
Mayhems is top of the list for our fluids range as I personally believe that no other brand comes close in terms of quality, performance and aesthetics.
But will you be doing plain distilled (or bi-distilled, etc.)?
I have no interest in using mayhem dyes, but it would be handy to be able to get decent distilled water.
EDIT: ah, just spotted this in the Mayhem line-up
EDIT2: Will you being stocking any corrosion blockers? (I like to be safe)
we will be stocking mayhems h20 that you linked.
i see no requirement for basic distilled water when we stock a premium grade product for what is essentially pennies.
i would use that over distilled tbh. the QC process for that liquid is worth the extra £1 or so you pay over plain distilled.
i am sure mlwood will answer any questions about that product when i officially announce the range tomorrow.
corrosion blockers are much of a muchness imho.
we sell killcoils and soon mayhems biocide.
i have the mayhems biocide in my family pc and it has sat there happily for 8 months without issue.
there is no need for a corrosion blocker if you have not mixed metals. which if you know anything about WC [which I am fully aware you do GM] then you shouldnt need them.
am i right in thinking you are using distilled+coil?
Yeah.
When I bought all my stuff I did buy some corrosion blocker (TFC I think) because I want to to be safe rather than sorry.
Now I'm pretty sure I shouldn't need it as I should just have copper (blocks), nickel (fittings) and brass (radiators I believe). Oh and some steel, but that's ok too isn't it?
It's pretty much just Aluminium you don't really want as far as I'm aware? And possibly Gold (seen some gold plated brass fittings).
Yeah Micks the king of coolent, He's a nice guy as well <3 ;)
Yeah.
there you go then - i dont need to educate you :D
he is indeed and he is now an active contributor to OcUK :)
The latest addition to the range ;)
OcUK V12 ULTIMATE Watercooled Case - Cooler Master ATCS 840 @ £449.99 inc VAT
The Ultimate Watercooled Case has arrived. Using only the finest watercooling components available, this case has everything that you require to build the ultimate system.
All of our pre-watercooled cases are built to order and ship pre filled ready for you to build your dream system.
All you need to do is build your PC and install the waterblock which is just as easy to do as mounting any CPU cooler.
All leak testing and filling is carried out by our technical staff which means that the watercooling system is ready to use by you when it arrives. All that is required is for you to plug the pump and fans into your power supply.
Component List:
1X Cooler Master ATCS 840 Classic Case - Black
One of the most versatile Watercooling Cases on the market, with the design and reputation that few rivals can beat.
1X Hardware Labs Black ICE SR-1 360 Radiator
Ultra high air flow and innovative built in shroud design offers uncompromised performance that is second to none.
1X EK Supreme HF CPU Waterblock - Copper Plexi
The most popular waterblock on the planet, and for good reason. A mixture of market leading performance and superb build quality. It's called the 'Supreme' for a reason!
1X EK DCP 4.0 Pump (12v)
A higher performance pump that offers capability alongside a smaller footprint inside the case.
1X EK Reservoir Combo DCP 4.0
A direct input reservoir that provides maximum flow to the pump at all times.
1X EK DCP Mounting Plate Kit
The best solution for mounting the EK DCP 4.0 Pumps
6X EK PSC Compression Fitting 7/16 [16/11mm] - G1/4 - Nickel
Trusted and reliable fittings. These fittings ensure a tight grip on your tubing for long lasting reliability.
1X Mayhems Ultra Pure H20 Watercooling Fluid
The purest water available - ensuring the best temperatures.
3X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin Fans
The most recognised performance fans for watercooling radiators.
Only £449.99 inc VAT.
ORDER NOW
