Hi Guys
Today we have launched a new range of OcUK assembled pumps.
Following the success of our EK range, we have tested a number of leading pump tops to bring you this new range. Alphacool stands out as being very similar to the fantastic EKWB tops but for a little less money.
I am sure everyone will agree that they look great!
All of the combos have a saving over the individual parts and are assembled in house by OcUK technicians who are watercooling experts.
We also list the Alphacool Tops separately now meaning you can upgrade your existing pump!
OcUK D5 Vario Pump & Alphacool HF D5 Top Value Combo @ £79.98 inc VAT
Assembled in house by Expert OcUK Technicians
The D5 is the king of watercooling pumps. Used in the most extreme watercooling systems, its notoriety for reliability and performance is second to none. A single D5 can run entire loops with multiple blocks and restrictions with ease, ensuring your watercooling installation goes smoothly.
The specially selected Alphacool top improves the performance of the already impressive D5 pump further.
This aftermarket pump top improves performance by increasing the heas pressure created by the pump. This means strong consistant flow around your loop and no slow points or hot spots.
The Alphacool HF D5 Top also gives the user several configuration options by adding the ability to use standard sized watercooling fittings as well as controlling tubing layout.
Every OcUK D5 Vario & Alphacool HF D5 Top combo is assembled by an Expert OcUK technician and tested for quality assurance before it ships to the customer.
D5 Pump Specifications
In response to the overwhelming demand for a quieter MCP655, we are proud to introduce the new MCP655 pump, which features several key improvements: considerably reduced audible operating noise: the high pitch frequency of the MCP655 is now eliminated thanks to a new chipset controller, head and flow characteristics have slightly improved in the midrange,
a potentiometer allows you to adjust the pumps speed from 4800 rpm down to 1800 rpm. At 1800 rpm, the pump is virtually silent. This allows users to tune the pump performance/noise ratio to their particular preference.
- 50,000 hours MTBF (Mean Time Between Failure) equivalent to 5 years lifetime.
- Superior 12 Volts DC convenience: plugs into the computer power supply
- Superior real world performance versus any aquarium pump we have tested to this date.
- The high pressure capability of the MCP655 is particularly well adapted to high-flow systems using 1/2" ID tubing
- Pump speed can be adjusted to yield top performance or virtually silent operations
- Maximum discharge 317 GPH (1200 LPH)
- Compact design
- Quiet operations even at high speed thanks to new chipset controller
- ½" barb fittings
- No maintenance when used with de-mineralized water and additives
Alphacool HF D5 Top Specifications
As with the version of Laing DDC is this the pump easily modified and can be mounted by the supplied mounting screws in a drive bay. In addition, in this case only the normal 1 / 4 inch connections are needed, not as before 1 / 2 inch male thread which can be adaptation. Of course, the flow is not affected!
Technical specifications:
• Material: Acetal
• Color: Black
• Connection thread size: 4x ¼”
• Dimensions mounted (L x W x H): 80 x 45 x 80mm
• 1x Alphacool HF D5 TOP - Black Acetal G1/4 - (VPP655/TPP644/MCP655)
• 2x Copper plated screw plugs
• Black mounting screws
Only £79.98 inc VAT.
ORDER NOW
OcUK 10w DDC Pump & Alphacool Acetal Top Value Combo @ £65.98 inc VAT
The Liang DDC is the most reliable watercooling pump design. Used in the most extreme watercooling systems, its notoriety for reliability and performance is second to none. A single DDC can run entire loops with multiple blocks and restrictions with ease, ensuring your watercooling installation goes smoothly.
The specially selected Alphacool Acetal Top improves the performance of the already impressive DDC pump further.
The EK Xtop also gives the user several configuration options by adding the ability to use standard sized watercooling fittings as well as controlling tubing layout.
Every OcUK 10w DDC Pump & Alphacool Acetal Top V2 Value Combo is assembled by an Expert OcUK technician and tested for quality assurance before it ships to the customer.
DDC-1 Pro (10W) Spec:
• Nominal Voltage: 12 VDC
• Minimum Starting Voltage: 9 VDC
• Nominal Power (@12 V): 8.3W
• Motor Type: Electronically commutated, brushless DC, spherical motor
• Max. Head - Blue Impeller: 3.7m
• Max. Discharge - Blue Impeller: 564 lt/hour
• Temperature Range: Up to 140°F (60°C)
• Electrical Connector: 4pin Molex
• Weight: 7.3 oz (207 gr.)
• RPM Sensor: 3 pin connector
Included:
• (1x) Laing DDC Pump
• (1x) Alphacool Acetal Top
• (4x) 20mm Stainless Steel M4 Phillips Head screws
NOTE: This pump has a blue wire 3pin wire seperate to the power lead, attach this to the Motherboard for RPM monitoring. You can also program the bios to shut down the pc or sound an alarm on RPM drops
This pump combination does not include fittings. You will need to purchase additional fittings for this item.
Only £65.98 inc VAT.
ORDER NOW
OcUK 18w DDC Pump & Alphacool Acetal Top Value Combo @ £69.98 inc VAT
Every OcUK 18w DDC Pump & Alphacool Acetal Top Value Combo is assembled by an Expert OcUK technician and tested for quality assurance before it ships to the customer.
DDC-1 Pro (18W) Spec:
• Motor design: Electronically commutated, brushless DC, spherical motor Voltage
• Range: 8 to 13.2 VDC
• 9 VDC required to start
• Motor rated at: 18W
• Max. delivery rate: 600L/h
• Maximum system pressure: 21.75psi, 150 kPa (1.5 bar)
• Temperature range: Up to 140F (60C)
• Corrosion resistant
• 50,000 hours mean time before failure (MTBF)
Included:
Only £69.98 inc VAT.
ORDER NOW
Alphacool Laing DDC Acetal Top @ £11.99 inc VAT
The perfect cover for the Laing DDC pump.
This cover is designed to replace the original cover of the Laing DDC pump to allow use of G1/4" fittings. With the help of decoupling kits (decoupling category) the Laing can be installed completely decoupled in 3.5" drive bays respectively on the case floor with standard decouplers. It is even possible to install the pump instead of an 80mm fan. With this cover a multitude of mounting possibilities is given, your imagination is the limit for your projects! A further opening is intended for the optionally available reservoir. With this option the cover can be used as a fully functional reservoir, still permitting the use of versatile decoupling options.
Dimensions (LxWxH): 80x80x25mm (Without fittings, without pump)
Weight: 180g
Material: Acetal
Mounting; 4x M4 threads, 8x Decoupling
Connection threads: 3x G1/4" threads
Extent of delivery:
1x Alphacool Laing DDC Acetal Top
Montingscrews
Screw plug G1/4"
Only £11.99 inc VAT.
ORDER NOW
Alphacool HF D5 TOP - Black Acetal G1/4 @ £21.98 inc VAT
The ultimate top for your Alphacool power pump offers even better performance as well as more mounting and connective possibilities for your favorite pump!
The base performance of the Alphacool TPP & VPP is already truly exceptional, but what if there is a possibility to improve even on that? This idea was also what has driven the developers which have created a product that does not only increase performance but also offers other additional advantages over the base model pump.
One of the greatest advantages are the G1/4” connection threads both at the sides and top of the pump cover. Both can be used separately or even in a combination. For the unused connection threads two knurled copper plated screw plugs are included.
The design is also a factor which was not taken lightly! The elegant black Acetal material with integrated Alphacool logo gives a clue of the potential of the German Know-how in these tops!
Mounting is done quickly and easily. With a simple twisting motion the motor is separated from the mount. After that you will find 4 separated basic components. First pull the O-ring over the polished silver front piece of the pump and then push on the largest of the 4 components. At the back, where the cable is coming out of the case, the counterpiece is pushed on. With the included mounting screws the elements can be tightly connected and you are done!
And what purpose has the last plate? It can be used for mounting of the pump in the case! Simply screw the plate to the pump’s top and the opposite side to the case or decoupling module and you are set to go!
And you will notice: This is yet another great piece of engineering from the Alphacool team!
Material: Acetal
Color: Black
The installation manual of Alphacool HF D5 TOP you can find here as Download.
Extent of delivery:
Please note:
Delivery without pump!
Only £21.98 inc VAT.
ORDER NOW
- Compact design
- ½" barb fittings
• Material: Acetal
• Color: Black
ORDER NOW
Included:
ORDER NOW
Included:
ORDER NOW
Weight: 180g
Material: Acetal
Extent of delivery:
Montingscrews
Screw plug G1/4"
ORDER NOW
Material: Acetal
Color: Black
Extent of delivery:
Please note:
ORDER NOW
