hi, ive been reading these forums for a while now and i can usually find an answer for every problem i have, but in this case i can not find an answer, so any help will be appreciated!
I recently bought some ocz el ddr platinum 2gb, im using it on an abit an8 fatal1ty mobo. my problem is that with both sticks of ram in the board the spd reports the ram at running at ddr200 and cpuz reports the same. any attempt i make to run it at ddr400 stops the pc from posting even at 2.8v. i can run it at ddr333 tho with no problems. If i use just 1 stick of ram it runs at ddr400 no problem also. what i have noticed tho is that 1 sticks spd has spd timings of 2 3 2 5 ddr400 and the other is 2.5 3 2 5 ddr400. which i think is rather weird.
Is there something i am missing or is the ram faulty/incompatable.
Many Thanks
Many Thanks
