New P5B-D Bios - 0711 - but some problems
20 Aug 2006
Reasonbly OK - lots of bug fixes according to the .txt - BUT CPU speed incorrectly reported in bios and on boot-up ! If overclocking always says 2.99 gig ! Checked with a friend, and on upgrade his bios reports the CPU speed incorrectly too !
Bios reportadly fixes the "double-boot" I wonder if the CPU speed fix is something to do with that.
ftp://dlsvr02.asus.com/pub/ASUS/mb/socket775/P5B Deluxe Wifi-AP/P5BD0711.zip
P5B Deluxe Release BIOS version 0711
1. Fix DRAM frequency incorrectly display problem under auto, standard and AI N.O.S mode
2. Add check ATI CrossFire VGA card routine
3. Add ASUS Cross Graphics Impeller (ASUS C.G.I) feature
4. Reduce system full reset of times
5. Patch some VGA card can''t found when NB Vcore value has been set too high
6. Fix DDR frequency 889 unstable by SPD
7. Enable support for NVIDIA 7950GX2 cards under recovery mode
8. Fix CPU frequency not correct when use ES CPU and lock free fuction enable
9. Fix memory display message not correct under multi-language
10. Add new CPU Ucode to support Kentsfield B3 stepping CPU
11. Fix chassis fan 2 speed not correct when fan speed too low
12. Fix ATI CrossFire can''t work when using with 800FSB Prescott CPU
13. Enhance Chassis Q-Fan sensitivity
14. Improve memory compatibility
Flashed and working fine here.....shows speeds correctly as before ::)
Also, the double-reboot on restart has indeed been fixed !!
What speed is your CPU running at, is it overclocked & if so whats your FSB?
did you flash in windows or dos
some people at xs think that flashing in windows will show the incorrect cpu speed
hi there - flashed via Bios-USB Key route.
CPU speed at the time = 2.88G - showed as 2.99G
now CPU speed is at 3.2G - still shows as 2.99 - but Orthos stable, and CPU speeds correct in Windows
Double boot definately has gone - CPU temps seem a bit lower too !
Mark.
thanks for the link to the thread, very useful - that would probably clear it - just a bit of a pain to get to jumper at the moment.
tbh - if its only mis-reading in bios - and is Orthos stable - does it really matter?
probably not.
Mark.
Hmmm, never had any problems with this "double reboot" but when I press the power button, the fans spin for a second then switch off... it then boots properly after a few seconds. It has done this with all three BIOSes I have used. I've tried the power button plugged in both ways before you suggest that. :rolleyes: :p
I'm running at 9 x 400 (3.6Ghz), with ram on 4:5 ratio, so at DDR2-1000.
Flashed using Windows Asus Update.....:)
