Hi
I'm trying to put together a new rig and am running into problems with booting up.
The spec is:
Asus P6T X58, Nehalem 2.93, 6GB Dominator, Stock Fan, BFG 280 1024 OC, 3 HD's with a 150GB Raptor X holding the OS, all in a CoolerMaster HAF.
Everything appears connected correctly and spins up, so I can get into the BIOS and see the 3 HD's all connected, along with the CDDVD and Floppy, so I've set the boot priority and the date.
The Raptor has Vista X64 on it from my old rig (in sig) and a second WD AAKS has XPSP2. My Vista is OEM, and as I've changed the Mobo due to it failing I'll need to contact MS - this may be relevant, not sure.
Only after rebooting I get past the POST, so my two boot options of Vista or XP are listed, but after choosing Vista there appears to be a loading and then a very brief BSOD is flashed up and it restarts.
So, I've changed the boot priority to the CDDVD and have inserted the Mobo's driver disc, only all that seems to do is want me to create a boot floppy.
Where have I gone wrong? what should I be doing?
Ideally I need this sortred for tomorrow so I can RD into the office!!! So many thanks in advance!
Simon.
The spec is:
Simon.
