New Parts
31 Jan 2007
Hello,
Below are my current system specifications:
Intel Core 2 Duo E6600 2.40Ghz
Asus P5W DH Deluxe
2 x A-DATA Value Series 1GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) - Model: VDQVE1A16
Asus ATI Radeon AX700 Pro 256Mb
Seagate 400Gb Sata2 HDD
Arctic Cooling Freezer 7 Pro
530W Hiper Modular PSU
Super Flower Blue Case
Asus DRW-1814BLT Lightscribe DVD-RW
NEC DVD RW Drive
Floppy Drive
Yusmart 198YP 19" Monitor
24 in 1 Card Reader
300Gb Maxtor One Touch 3
Logitech MX 1000 Mouse
Microsoft Windows Vista - Home Premium 32bit
I am considering purchasing the folowing components:
1 Mountain Mods U2-UFO Black Powder Coat - Original Top
1 ThermoChill PA120.3
1 12V Laing D5 Vario Water Pump
1 Swiftech Apogee GTX 775
1 Swiftech Micro Res
1 1/2" ID Flexible tubing
15 Zinc Plated Jubilee/Wormdrive Clip 1/2"
1 Feser One Coolant UV Green 1L
10 120mm Yate Loon D12SL-12 Blue LED Case Fan - UV Clear
1 Zalman ZM-MFC2 Multi Fan Controller
The reason: To keep my processor much cooler as it's currently running at about 50 degrees C at idle. It is overclocked to 3.0Ghz.
Is there anything missing from the water cooling parts I ahve listed which i would need. I ahve never had a go at water cooling before therefore I do need a slight bit of help. Will all of this fit in the case? and can anyone try and direct me to a site where i can purchase the fans I have listed as i cannot seem to find them anywhere! Also, what length of tubing do you think I would need with the case and me never tried WC before?
Thanks
Neil
rctneil said:
Can anyone help me here?
Regards,
Neil
Everyting will fit in that case.
You will probaiblly only use like 6ft of tubing but buy 8 or 10 just to be safe.
Hey,
I may be purhaisng my new case and watercooling parts soon. I would like to know what colour fesser Uv coolant would go with the blue lighting within the case. Would green be ok?
Thanks
Neil
